Hif 44 Help, Only Runs At Co12%
Posted Today, 09:28 AM
Any suggestions on a HIF 44 1275 1992 mini (carb conversion)
Can’t keep the engine running unless it’s warm and set crazy rich at 12% CO (even then it bogs out and cuts out when little throttle). If set around 2.5% /3.5% with warm engine then engine is revved and left to settle the mixture goes to 0.5% and cuts out. I recently put the standard air box with k&n and drilled holes instead of a cone filter . Set timing with strobe light and changed the dash pot oil from what looks like ATF to 20/50 but still no difference, spark plugs changed to BP6ES and gapped correctly. Su rebuild kit is on the way to try this week.
Posted Today, 10:19 AM
On mine, my troubles - running far too rich - were the starter ('choke') seals leaking fuel and permanently enriching it. Trying to set mixture was a complete headscratcher until it was fixed.
It's also worth looking for air leaks into the manifold, from the usual places including servo if you have one.
Posted Today, 10:33 AM
Check that the piston always returns correctly. I have seen one that wouldn't fully return in certain situations. It felt fine but showed up on an exhaust gas analyser.
Do you have the readings from the other three gasses?
Can you post some photos of the engine bay?
Posted Today, 11:42 AM
I’ve cleaned the piston and it returns fairly smoothly when not running.
Posted Today, 11:53 AM
Posted Today, 11:57 AM
Have you tried returning the car to the state where it was running?
I think a K+N in a drilled airbag will improve the fuelling; the old air filter set up you describe usually leans out the fuel mixture. Maybe the carb had been set to compensate for the extra air.
Do you have a Haynes to set the idle speed?
Good luck with the rebuild.
Posted Today, 12:13 PM
Posted Today, 01:41 PM
Edited by Jay92, Today, 01:42 PM.
Posted Today, 01:48 PM
Float chamber venting, piston communication ports, spring & damping also possibilities.
...Saw the piccy so adding brake servo to the possible air leak list.
Posted Today, 02:23 PM
I have had that stripped down as the brake pedal was sticking down intermittently, maybe I’ve fixed a fault and created one. Il get the smoke tester out.
Thanks for your help
Edited by Jay92, Today, 02:25 PM.
1 members, 1 guests, 0 anonymous users
Richard e
