22G1128 Sm Remote Gearbox
4 replies to this topic
#1 Mito
Mito
  • 460 posts
Posted 23 June 2026 - 07:43 PM
I have an old 22G1128 gearbox that is surplus to requirements.
I've never run the gearbox as it came with a 1275 engine that I've not put in a car yet and I know nothing else about it. I'll probably be taking the diff out for use in another box.
Any idea how much it is worth?
Attached File  1000039013.jpg   70.75K   1 downloads
Attached File  1000039014.jpg   66.13K   12 downloads
Attached File  1000039021.jpg   43.63K   10 downloads
#2 Rocket.
Rocket.
  • 1,444 posts
Posted 23 June 2026 - 08:35 PM
As it’s got ADO16 diff housing and not mini that lowers the price somewhat but probably around £200 complete
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 24 June 2026 - 08:20 AM
Need to see a better picture of the gear condition, but £100 tops.
The fact it has pot joint output shafts indicates that it's already been worked on so anything could be hiding in there.
Edited by Guess-Works.com, 24 June 2026 - 08:22 AM.
#4 Mito
Mito
  • 460 posts
Posted 24 June 2026 - 06:24 PM
I think the guy I bought it off had rebuilt it. The engine doesn't have many miles on it since rebuild, can still see honing marks, though looking at other threads on here, I now suspect the engine is from an Austin 1300 as well.
#5 Shooter63
Shooter63
  • 1,294 posts
Posted 24 June 2026 - 06:35 PM
These gearboxes are ideal if you want to do what I call a 4 on 3 which is a 4 synchro gearbox with a 3 synchro magic wand change diff housing, if I wasn't the other end of the country I would give you a look. Good luck with the sale.
Shooter
