Cold Start Issues
2 replies to this topic
#1 MrRussells
MrRussells
  • Validating
  • 33 posts
Posted 25 June 2026 - 04:48 PM
Hi All
I hve posted about this before and made some changes but still in the same situation.
Late summer 2025 my Mini refused to start unless I used quick start into the injector. Once the car had heated up it started first time and ran fine.
After research I have completed the following:
  • Regapped plugs
  • Replaced VAC Pipes
  • Changed Rotor Arm
  • Cleaned Distributor cap
  • Changed Ignistion coil and leads
  • Changed Coolant Temp Sensor
Since then, I am still getting the cold start issue but now only runs on 2 cylinders (I believe this is an issue where I have not torqued up the inlet tight enough) PITA to get to.
I have continued my search to identify the issue and someone has mentioned the Air Temp sensor can cause this issue.
Am I right in thinking that becuase this runs fine onces heated up it rules out Electrical and Fueling issues ?
Russ
#2 68+86auto
68+86auto
  • 1,461 posts
Posted 25 June 2026 - 10:36 PM
So what does the ECU say the coolant temperature is?
#3 NLinPEN
NLinPEN
  • 179 posts
Posted 26 June 2026 - 06:47 AM
It is difficult to give any hints as long as it is unknown what the ECU thinks of it. Having a download of the ECU's sensor readings at cold start and warm start would be very helpful.
