Mini Clubman Mk3 1974 Rear Seat Belts.
Posted Today, 03:15 PM
I would like to fit some fixed seat belts in the rear seats.
I can’t find any rear fitting holes for belts.
Can you tell me if there is a belt kit I can buy.
Mini Clubman mk3 1974.
Any help gratefully received
Regards Ian.
Posted Today, 03:51 PM
varies from model to model and I don't know the years
but.. standard you should have at least lap belts so that gives you the clicker fixing point (whatever that bits called lol)
if you look at your C posts is there a big threaded bolt hole there under the trim, to fix the top part (you can buy alternative panels to spot weld in but obviously it's a fair bit of work)
and then down in the rear bins each side you either have the reel fixing bracket, or you don't. I didn't, so I welded them in. then again I'm full strip and rebuilding anyway, it's not a quick easy job you can just do in a weekend (unless you're really well kitted out and do that sort of thing all the time)
there may be alternative kits to suit cars without the brackets in the bins but I'm not aware of them or how they'd work
Edited by stuart bowes, Today, 03:51 PM.
