Fan Runs When Engine Not Yet Hot
Posted 06 July 2026 - 07:03 AM
I thought that the ECU and gauge took their reading from the same temperature sensor on the thermostat body but I don’t understand why the gauge would read just above the minimum when the fan switches on, whilst also going on to read normal operating temperature once the engine warms up.
Any ideas?
Thanks, Steve
Posted 06 July 2026 - 07:42 AM
Has the car had the recall fix?
The original temperature sensor cables were too short, allowing engine movement to stress the conductor in the cable.
Since, as with most Engine Management systems, a component, or connection, fails to "Safe", if the continuity in the cable is broken the fan will be switched 'On'.
Minispares has the Harness Coolant Fan Modification. Rover Tech Bulletin 0043, in stock.
Sign up to TMF +. Message Simon, at Mini Spares, and get £1.25 discount (25% of your annual subscription) and 7.5% off any other items you may need.
Cable.jpg 40.46K
1 downloads
Posted 06 July 2026 - 09:18 AM
Thanks, Steve
Posted 06 July 2026 - 10:45 AM
Having had the issue, the temp gauge on mine registered normally, replacing the cable meant the fan only came on at the appropriate times.
I imagine the gauge is a fed multiple sample resistance output but one open circuit reading triggers the fan.
If you want to, you could try disconnecting the wire, shortly after starting from cold, to see what happens
Posted 06 July 2026 - 11:35 AM
Does it not have a thermal switch in the radiator? I'm sure some Minis with auxiliary fans do, operates independent of the gauge.
Posted 06 July 2026 - 12:55 PM
Not on the MPi, Ethel.
Posted 06 July 2026 - 05:57 PM
Ok, didn't didn't realise it was an MPI, not that I'd have been that much wiser....
I think I'm right in thinking there's a relay and the ECU will likely control it by sinking (earthing) the earth. So it could be the relay, or a related earth fault
Posted 06 July 2026 - 06:12 PM
Posted 06 July 2026 - 06:34 PM
Wiring diagram shows a light green/ black trigger wire running from the relay to 28 on the ECU.
Posted 06 July 2026 - 07:39 PM
Steve
Posted 06 July 2026 - 08:56 PM
Would an open contact not show on the gauge - though I suppose if it was only momentary?
The Mems supplies the coolant sensor from 15 with a pink/green wire and has a shared -ve return with the TPS, MAP & air temp sensors, pink/black at 13 - if you don't have the wiring diagram.
Posted 07 July 2026 - 07:11 AM
A strange one this, the fan starts up before the engine gets to temperature but the temp gauge works as it should and the sensor appears to change resistance with temperature as per other posts. I’ve also checked the wiring and can’t see any chafing. The fan runs continuously until you switch the engine off again.
Any ideas?
Thanks, Steve
Is your car an MPI or SPI? On the SPI there is a separate switch that controls the fan. It is located at the bottom of the radiator.
Posted 07 July 2026 - 07:36 AM
Posted 28 July 2026 - 11:51 AM
Thanks for the help,
Steve
