Injection Or Carburation
Posted Today, 08:49 AM
I love reading about other options and I recently read up on aftermarket efi. After researching it a bit more I cam across a post on the turbo mini forum about efi.
https://www.turbomin...p=vt&tid=395643
It's 4 pages but it's interesting reading about how aftermarket efi doesn't really do as much as it promises. Was the MPI really good? Despite 30 years of advances in tech is the MPI still as good as it can get for the 5 port.
I've only driven 1 MPI briefly and it was unbelievably smooth
Posted Today, 12:54 PM
I think we'd be fooling ourselves if we thought we could make much in the way of improvements over what BMW could achieve with their experience & budget. Even so, if we wanted something a bit different to what they offered with the MPI we might find a different engine management system can do a better job of that.
It's valid to think of the ol' A series as a 2 cylinder engine wrapped round a different 2 cylinder engine because of its siamese inlet ports in particular. A cam sensor, like the MPI has, is essential if you want to cater for the specific needs of each of those 2 cylinders. Any aftermarket system that doesn't have a cam sensor input is at an innate disadvantage. Notable that a lot over on TurboMins also went to 7 port heads when they started moving over to fuel injection.
Posted Today, 01:00 PM
Also interesting to read Mike Theaker's (BMW/Rover Engine Development Engineer) account of the Mini MPI development story and how it was BMW's will and John Cooper's insistence that finally got the MPI into production in 1996, extending the Mini's life by 4 more years. Mike Theaker also later worked on powertrain development for the New MINI (R50).
Mike Theaker on the Development of the Twin Point Injection system for the Mini.
Link to PDF below:-
https://www.turbomin...ts/493117-1.pdf
(Article in the link above is from the September 2000 issue of Miniworld magazine)
MPi Mini Development Story:-
https://www.theminif...elopment-story/
Edited by mab01uk, Today, 01:03 PM.
Posted Today, 02:16 PM
The MPI system is very good because it is fully sequential,something that aftermarket was slow,or never,adopted.the drawback is you need to control large injectors to be able to fully inject the charge into the proper cylinder.this may limit fuelling.Steve..
Can you explain sequential as opposed to.....
Do you mean large cc injectors? I thought that was a problem as then the control at low load or low rpm was difficult?
Posted Today, 02:21 PM
So the cam sensor is a big advantage over a crank sensor?
Posted Today, 04:40 PM
The crank sensor will always do the timing of the injection & sparks. The cam sensor is needed to know which cylinder to inject for because (on a 4 cylinder engine) there'll be two cylinders moving together. One pushing the piston down the bore after firing, the other drawing in the next charge through the inlet valve. You can only inject fuel in to the second one, but if you fired its spark plug along with the cylinder about to start its power stroke it wouldn't matter: as there'd only be exhaust gasses in it. That's what's called wasted spark ignition and it doesn't need a cam sensor.
Posted Today, 05:39 PM
