Hi All
First post and need of some assistance please
Quick history- bought from UK and shipped to S France, where it now lives.
Car seems to be overheating to around 110 degrees indicated.
I have not pushed it hard when hot and put cabin heater on to help limp home gently
Yes I know car is not designed with current weather in mind, but has only been driven short distances in 20-25 degrees temps and cabin heating turned on when temps rise above 90 degrees.
Longest run in 25 degrees heat has been 30 mins, with temps rising after 15-20 mins
Only symptom is the gearbox gets really notchy, but only when +90 degrees
As most of the cooling system has been replaced (including water pump and oil cooler - which were not listed) my thoughts turned towards the thermostat, as perhaps the PO put a cold temp thermostat in for the UK
I bought a 74 degree thermostat, but to my surprise..... there was no thermostat installed ![]()
I installed the lower temp thermostat and now wondering my next move!
Ideas are to borrow or buy a infra red thermostat gun to verify temps (but pretty sure it is overheating)
Then flush radiator
Then replace water pump for a higher flow pump
Any other advice appreciated please
Another question: engine running with radiator cap off - should I see any water flow? turbulence?
As currently the water is dead still!
The answer to this might make me just head straight for the pump and impeller replacement!
Here is a list of the engine refit done by PO - will try and figure how to upload a couple of pics in the meantime
Many thanks, Ben
Engine & Gearbox
• Original block acid dipped, crack tested, skimmed, main caps line bored
• Repainted correct late BMC Mk2 colour
• Genuine Rover cam bearings fitted and line bored
• Conrod little ends re bushed 0. 001” clearance
• 1098cc crank ground 0. 010” on mains and big ends. 0. 0015” clearance on mains and 0. 002” clearance on big ends
• Mahle Motorsport main and big end bearings, crank end float 0. 003”
• County 1098cc floating + 0. 020” pistons. Block honed to suit 0. 022” piston to bore clearance Rings gapped to 0. 012”
• 12G202 Cooper cylinder head acid dipped, crack tested, skimmed, ports polished, new original spec valves, 8x new unleaded seats, new bronze guides, new Cooper S double springs, new competition top hats, new competition cotters, new R clips.
• New cylinder head and gearbox stud kit
• ARP block and rocker studs
• Ac Dodd 998 Road torque cam, set at 106 degrees TDC
• New cam thrust washers
• New gasket set throughout
• New water and oil pump
• New pressure relief sleeve, bullet and spring
• New water hoses
• Borg and Beck clutch kit
• New 45D points distributer
• Lucas Gold coil
• 5ES NGK Spark plugs, new leads
Edited by CaptBen, Today, 10:15 AM.
