Mpi Overheating
Best Answer john2502 , 18 August 2026 - 02:44 PM
Hi all, so now have this resolved and just thought would put for any future reference.
I ran out of ideas so guy at local garage took a look with thermal camera, turns out rad was actually pretty blocked so replaced that and figured while doing it fit a new minispares waterpump as well.
Then looking at the heater matrix was as also pretty clogged so figured would replace this at the same time as well rather than all that possibly wash back around. Got a decent quality one from the place below (wasn't 100% sure on the quality of replacements)
https://thecarheater...x-1992-onwards/
So in the end yeah, I was obviously feeling the part of the rad that felt hot but not as hot as it should have. Now basically have a whole brand new cooling system, all apart from the kitchen sink. Go to the full post
36 replies to this topic
#31 john2502
john2502
  • 165 posts
Posted 04 August 2026 - 09:03 PM
I had the same issue in another thread on my MPI too.
Did all of the same things (except my thermostat was KNACKERED too), and i just happened across the fact that my alternator belt was a bit loose. Since it does also spin the water pump it was possible that under load it was slipping and not spinning the pump correctly to give a decent water flow. Other cars you hear it squealing, but i never noticed it with the mini.
My tensioner was basically seized and took a load of effort to get it off and adjusted. But once i got it back on and the tension back to how it should be, the car has been fine since.
So definitely worth checking.
Oh really? Did yours also go the middle, settle for a while, then steadily climb after fn came on.
Funnily enough I do have a replacement belt as when I replaced the alternator a couple of years ago I misplaced the belt at the time so had to fit the old one back again. It looks to be spinning fine but definitely worth a check along with the check on the header tank for exhaust gases. Cheers.
#32 john2502
john2502
  • 165 posts
Posted 04 August 2026 - 09:05 PM
Hi,
you say your radiator is hot all over, should it be ? shouldn't it be cooler down the bottom where the coolant has been cooled ?
Sorry should have been clearer. Yes I mean radiator felt as I'd expect basically. If it was blocked I think it would have been much colder than I felt basically. I still won't rule it out 100%. At tia point I am just hoping it isn't the head gasket but sadly it's the front runner at the moment.
Plan is test on the header tank for emissions as no other signs of gasket, replace belt, maybe remove and inspect water pump, then head gasket is all that's left really.
Bloody cars eh! Haha
#33 dan1zo
dan1zo
  • 72 posts
Posted 05 August 2026 - 08:25 AM
Hey, so yes similar. It would idle on the driveway from cold start perfectly fine, it could get to temperature and stay there in the middle, fan would kick in around the right time and it all be fine.
For me also the same, the water pump looked to be spinning ok, but you can't tell if its slipping when driving! haha
But if i drove for more than 5-10 minutes, the gauge would spike and coolant would boil and release through the pressure valve in the header tank cap.
I tightened the belt so it had about 10mm deflection when pressed and so far so good.  I replaced the water pump about 10 years ago, when the original one failed, with a minispares replacement for the mpi that had a larger impeller.
Edited by dan1zo, 05 August 2026 - 08:29 AM.
#34 john2502
john2502
  • 165 posts
Posted 18 August 2026 - 02:44 PM   Best Answer
#35 pete l
pete l
  • 1,537 posts
Posted 19 August 2026 - 06:47 AM
That heater matrix isn't the MPI one, it might fit though, I don't know.
#36 john2502
john2502
  • 165 posts
Posted 19 August 2026 - 11:43 AM
Really? It's listed as 92 onwards and seems to fit ok
it looks different admittedly as the inlet/outlet pipes are welded directly on instead of separate pieces but I just didn't trust the Chinese repro matrix. They are probably fine but for the sake of £60 extra for just my peace of mind it made sense to me (I daily this car so rely on it to get me to work and the kids to school!, so any breakdowns are a bit of a headache)
#37 pete l
pete l
  • 1,537 posts
Posted 19 August 2026 - 01:31 PM
If it fits :-)
