Front Suspension Bolts
8 replies to this topic
#1 COX1E
COX1E
  • 31 posts
Posted Today, 12:26 PM
Hi All,
I recently had a knocking from the front suspension, which I found to be a loose bolt. I tightened it, and the knocking has gone, but I am not happy with the bolt length, as it doesn't come all the way through the nut. I decided to buy new bolts, which I fitted today, and they're the same. My question is, have I got the wrong shocks on the car? it's the same on both sides, of that car.
Any help would be much appreciated
#2 sonscar
sonscar
  • 3,218 posts
Posted Today, 01:31 PM
You seem to have a bump stop kit of some type and the spacer to clear it is causing your problem.Normally the spacer is not needed.Steve..
#3 COX1E
COX1E
  • 31 posts
Posted Today, 01:43 PM
Cheers for the reply,
Without the spacer the shock would hit the bump stop bracket. Do I need a different bump stop?
I thought it looked like the rubber is sticking out of the shock too far, but I don't know if that's normal.
Could you send a pic of one that is correct please?
Edited by COX1E, Today, 01:44 PM.
#4 Shooter63
Shooter63
  • 1,268 posts
Posted Today, 01:52 PM
Unless your car was/is a hydro car, somebody has fitted a hydro competition bump stop kit, then cut it down for some strange reason, if running this set up you either need longer bolts or the hydro conversion pins, but those Koni dampers look quite fat, so even the conversion pins might come up short, so best go for longer bolts, as a stop gap change the nuts to normal type with a lock washer if it's your daily car.
Shooter
#5 COX1E
COX1E
  • 31 posts
Posted Today, 02:10 PM
OK, so I'll look to replace the weird bump stop for a standard one and see about a longer bolt. Where would be best to get a longer bolt? I assume it's not a standard length as the ones I have fitted are standard.
The car used to be a hill climb car apparently, so maybe that's why it has a strange set up. I just want it to be standard and safe.
#6 Earley86
Earley86
  • 14 posts
Posted Today, 03:39 PM
You could use any non specific mini bolt and nut as long as its the same diameter.
#7 Spider
  • 15,762 posts
Posted Today, 05:04 PM
The bolt appears short because of the Competition Bump Stop Bracket.
Before removing the Bump Stop to make the bolt long enough, I'll add that these are what I run with and compared to stock Bump Stops, these are night and day, and for a few reasons.
You just need to buy 2 new bolts 1/2" longer, not hard to come by - 3/8" UNF, Grade 8 x 5" long will do the trick.
#8 Ethel
  • 26,672 posts
Posted Today, 05:14 PM
The bolt will be "longer" by twice the thickness of the bump stop bracket. That should be enough, but it looks like  something is holding the washer under the nut farther off the rubber bush than it should.
#9 nicklouse
  • 19,020 posts
Posted Today, 05:35 PM
As mentioned. Longer bolt but you also need bigger washers.
4 members, 0 guests, 0 anonymous users
    Cooperman, imack, Shooter63, Spider
