Not starting, but it was a week ago!
urbantricker
, Nov 26 2006 08:59 PM
12 replies to this topic
Posted 26 November 2006 - 08:59 PM
Hi,
Me and my brother are now stumped for ideas, Ill explain what we have done and what has happened:
- Had a normal 1275 in my mini and it worked fine
- Fitted a A series (not a plus) 1380
- Bought new spark plugs, leads and coil for it.
- Bought a second hand distributor (points) which at first did not spark and the engine wouldnt start.
- We bump started it and it started and the points and spark plugs were now sparking.
- Occassionally it wouldnt start and would need bump starting, so I figured it was the distributor so I bought a brand new distributor and this solved that problem.
- We then fitted a fuel pump and weber 45 DCOE, took it for a spin and it worked fine.
- I hadnt driven my car for about a week and then we to start it and it wouldnt.
So thats what has happened. And this is what we have checked:
- Points and condensor are brand new and it is sparking in the distributor.
- Rotor arm is brand new
- When we test for a spark, it will only spark when held close to an earth, but not when the earth surrounds the spark plug. I am not sure if this is neutral.
- I put my old carb on which still didnt start it.
- So I put the weber back on, checked there was fuel in the chamber.
- I have tried my brothers' jets in the weber (his car runs fine)
At the moment all it does is turn over, but I did leave it overnight and then in the morning without switching the fuel pump on i tried it and it gave a little gurgle, but then nothing after that. We thought it might need a fuel regulator.
Anyone else have any ideas?
Thanks a lot!
Thanks a lot!
Posted 26 November 2006 - 09:06 PM
Is the battery fully charged?
Posted 26 November 2006 - 09:11 PM
Ah yes we had it on charge over night, forgot to mention that bit
Posted 26 November 2006 - 10:15 PM
Is your alternator charging?
And is the battery proven to be any good?
Posted 26 November 2006 - 10:38 PM
I had this same problem for a good while, I even took the battery back to the shop (4 months old) to be tested. They assured me it was good. I persisted and tried lots of other things until i finally tried a different battery. Bingo, the battery was duff
Posted 26 November 2006 - 10:39 PM
poor earth?
Posted 26 November 2006 - 10:40 PM
Earth strap?
Posted 26 November 2006 - 10:42 PM
you copying me slapper
Posted 26 November 2006 - 10:44 PM
Great minds...... !
Posted 27 November 2006 - 12:11 AM
deffo an earth problem
Posted 28 November 2006 - 10:39 AM
Hi,
Cheers for your suggestions guys. But I think I have solved it.
When I bought the spark plugs my brother told me to get some bike engine ones, i cant rememebr exactly the ones he mentioned but apprently everyone uses these on their minis.
Well it was working on these before, but I have just put in two old mini spark plugs and it started first time, I am going to buy a new set of mini plugs tonight and hopefully it should be running nicely.
I will let everyone know....
Posted 28 November 2006 - 11:01 AM
Interesting ! Dont they use these on the 7/8 port and 16v heads purely as nothing else will fit ?
What do the duff plugs look like ? Cracked cores by any chance ? Can we have a pic ?
Posted 30 November 2006 - 01:08 PM
I will try and do it tonight, have been really busy with work recently!
I was going to go and buy some new mini spark plugs, but I will get the pictures as soon as I can!
