I got a new one (from the MG Owner's Club, who now do Mini parts). But when I took the old one off I found the rubber had completely disintegrated, as expected, but that the outer part of the bush was stuck in the gearbox housing. Tried a few taps with a screwdriver but it didn't want to move easily. Thought about making something the exact right size on my mini-lathe to go in on a threaded rod or something to push it out (mindful of Spider's advice to be careful not to crack the gearbox). But then had the idea just to try a bit of rubber strip. Had some of this left over from another project. It's about 1.6mm or maybe 2mm thick. Cut to the right size it fit perfectly: the inner cylinder was a firm squeeze by hand to go in, and then when I did the bolt it up it was all nice and steady and not wobbly.
Went for a drive and the gear changing feels lovely now. One of those things you get so used to over the years you don't notice it's got a bit loose (if you only drive one Mini).
1.jpg 45.23K
0 downloads
