This has happened intermittently several times - turn the key, click from the solenoid but starter doesnt turn.
Volt meter shows voltage drops to 6 or 7V at the starter motor and terminal very warm when key turned to start. Good 12.5V at starter side of the solenoid with the starter cable disconnected.
So whats happening? At first I thought the starter gear must be jamming on the flywheel but if its not spinning then the bendix wont be thrown? Can the starter motor just jam up?
One time, i got a bump start then it was fine for weeks although I did replace the solenoid thinking that was the problem. Couple of other times I removed starter, put it back on and again worked fine for weeks.
