Dipstick Length
7 replies to this topic
#1 croc7
croc7
  • 885 posts
Posted Yesterday, 08:36 PM
Since the 1275 block is taller by approx 10mm, were there different length dipsticks for each engine?  The reason that I ask is that I suspected the oil level indicated on the dipstick for this A+ Metro block wasn't accurate.  At my last oil/filter change, I did a careful check and found that with exactly 5 quarts and a small filter (a Mahle OC25) that the full level was about 1/4" below the MAX line on the dipstick.
#2 Earwax
Earwax
  • 595 posts
Posted Yesterday, 09:46 PM
No answer sorry- but i had assumed all were the same length as it was essentially the gearbox depth.. If clever people chime in on this , can you add details as to the different tops of the dipsticks please. I think A+ have seals - but without looking at aftermarket ones - I am curious about normal looking ones [finger loop at top]  and umbrella top with finger loop [see image]
Attached File  dipstick tube.jpg   26.45K   1 downloads
#3 nicklouse
  • 19,031 posts
Posted Yesterday, 09:58 PM
They are all the same. Except for the very early 850s. All the others have the sane level marks.
#4 mab01uk
mab01uk
  • 12,994 posts
Posted Yesterday, 10:18 PM
The extra height was added to the top of the 1275 block so made no difference to the dipstick length.
#5 68+86auto
68+86auto
  • 1,410 posts
Posted Yesterday, 10:19 PM
If you put the estimated quantity of oil and you are that close then that sounds like the dipstick is correct.
I have seen one where someone mixed up A and A+ parts meaning the dipstick was much higher than it should be. It would've required a lot more oil to meet the dipstick.
#6 nicklouse
  • 19,031 posts
Posted Yesterday, 10:28 PM
Sorry they have the same level marking. You can use either in either build. There is no difference.
#7 68+86auto
68+86auto
  • 1,410 posts
Posted Today, 01:24 AM
The dipstick itself may be the same length, but when someone adds a dipstick tube to an A+ it will be wrong. That's why I said parts, not dipstick.
#8 croc7
croc7
  • 885 posts
Posted Today, 06:17 AM
That would explain it then, thanks.
