Valve Guide Wear
1 reply to this topic
#1 coopertaz
coopertaz
  • 915 posts
  • Local Club: a-series-magpies
Posted Yesterday, 11:12 AM
i'm currently rebuilding an engine that only smoked on start up but not on overrun what amount of play, if any, is permissible in the valve guides? none are sticking, all valve stems are good with no wear marks but on  2 you can feel a tiny amount of lateral movement. New guide or will stem oil seals suffice? seals on there at moment are later type and not hardened or split
#2 Spider
  • 15,781 posts
Posted Yesterday, 05:39 PM
The running clearance on the valve guides to valve stems is 0.0015 to 0.0025" for the Inlets and 0.002 to 0.003" for the Exhaust Valves, the latter having a higher clearance as they run hotter and expand more.
Because of the small diameters here and that they don't wear round but tend to 'slot', they are difficult to measure. You can get an idea by using a DTI on the head or stem and rocking the valve.
With fresh engine builds, I have always overhauled the head, for it to properly run in, you really want to eliminate oil getting in to the cylinders and let that be controlled by the rings and cylinder honing, you also want to have the valve seats re-cut so they seal properly
