Clutch Master Cylinder- Service Or Leave?
Posted Yesterday, 11:20 AM
Posted Yesterday, 12:43 PM
Posted Yesterday, 01:44 PM
Posted Yesterday, 02:01 PM
That’s what I was worried about… the seals are currently the original seals so I know the quality is good but if I buy a service kit will the seals be as good? Or do I just leave as is and hope?
The kits we stock are genuine AP rather than aftermarket
Posted Yesterday, 03:55 PM
If changing the master cylinder, it is wise to fit a new flexible hose to the slave cylinder plus a new slave cylinder as well.
Posted Yesterday, 05:18 PM
The factory advice is to re-rubber the clutch (and brake) hydraulics every 3 years or 40,000 miles. While it's off, may as well overhaul it.
Posted Yesterday, 07:27 PM
I have recently changed the clutch master cylinder due to a fault which turned out to be the flexible hose. I am about to change the brake master cylinder, which is sensible as I have a single line system (Mk.1 Cooper 'S') and it's a well used rally car.
It's very easy and not expensive, except for fitting the clevis pins (worst job on a Mini?) I use an R-pin on the clutch clevis, but a proper split pin on the brake clevis pin.
In fact I have moved to the latest plastic masters.
Posted Today, 05:39 AM
Posted Today, 08:20 AM
MASTER CYLINDER CLEVIS PIN REMOVING AND FITTING TOOL
"A handy little tool for removing and replacing the master cylinder clevis pin. Sloped leading edge helps the tool to get behind the pin head for removal and the spring top stops it from falling into the bulkhead and holds it in place for replacement."
https://www.minispar...nd-fitting-tool
