Low-Boost 1275 A+ Turbo Setup On Jdm Mini
Posted 13 August 2026 - 01:21 AM
Posted 13 August 2026 - 12:51 PM
You're not far off the stock Metro Turbo there. It had a 9.4 CR, no inter-cooler & clockwork engine management. Of course we no longer have proper petrol, but you've got plenty of other advantages over the old Metty.
Any improvements to the gearbox will help, but the factory turbo was pretty stock with just a bigger 1st motion shaft nose bearing over its stable mates. A 3.2 final drive, but through Metty sized wheels 'n tyres, so you should have kinder gearing.
...Not many turbo Min builders bother with the nose bearing and the turbo pistons, though great, were probably overkill - possibly because they had homologating the Metty Turbo Challenge in mind.
T3 blower & modulated boost - could be wrong but I think it was something like only 3psi until it got into the A's asthmatic zone.
Posted 13 August 2026 - 04:20 PM
To this day I run a standard gearbox and bottom end although later this year I'm pulling the engine to replace the diff pin with a hardened one as mine has worn. I run it a 8 psi without an intercooler and it has been perfectly reliable for 3+ years as a daily. Mine comes on boost at about 2.5-3k but below that it is a bit gutless, I think that is down to the combination of the CR, 266 cam and running a HIF44 on a 998 but it wakes up after 2k. I do alot of motorway driving and my commute is 54 miles a day, the only thing I had an issue was with on long journeys at 70mph the coolant and oil got hotter than I liked, if I drove at 60 it was fine but 70 it would creep close to the red. I replaced the rad with the mini spares 4 core and fitted a 10 row oil cooler and it keeps temp perfectly now.
Posted 15 August 2026 - 08:43 AM
I must admit I've never understood why people keep fitting/recommending turbos off old diesel engines, obviously back in the day when turbo petrol engines were scarce you had very little choice, but over time various manufacturers have offered small capacity petrol turbo options in their line ups, the picture attached is off a 1.3 Glanza, as it has cast on it, its a CT9. From the factory boost was set at about .8 bar, the engine made around 120bhp, spooled really well and if you add a MAC valve or put an adjustable boost valve in it could go to around 150+ bhp, because the car was popular you can buy hybrid versions to increase the power to higher levels. You still find O/E ones on fleabay for the equivalent of a night out, fit a rebuild kit to it and off you go, or you have the option of a Chinese copy. Seems a no brainer to me.
Shooter
Posted 15 August 2026 - 08:51 AM
Anything higher than 6psi, get an intercooler fitted.
Posted 16 August 2026 - 04:52 AM
Thank you for the replies! Nice to hear that it sounds feasible.
I think I will definitely go for the cross pin diff as it's not too much more money compared to just upgrading the pin, and I have heard it can be quite catastrophic if the diff fails. Are there any other parts that need to be changed when swapping to a cross pin?
As far as cr goes, would I be able to get away with just running double head gaskets and leaving the combustion chambers as they are? I want to avoid a decompression plate as i've read they can mess with the rocker geometry. according to the cmdiy calculator, double head gasket would get me to about 9.3, would that plus an intercooler be safe to run a bit more boost than the 3psi that the metro turbo had as Ethel mentioned?
Sidenote- would anyone know where I can find reliable figures for my 1999 jdm 1275 to put into the calculator (piston dish, combustion chamber volume, piston deck height, stroke length)??
If youre able to data log, see what the injector duty is at, as when you add boost and rpm, the quantity of fuel required goes through the roof as the afrs needed will have to cool the piston crowns, and cater for the scavenging.
This is a great point thank you Steve. I currently have a singular 66lb/hr ev14 injector which is at about 25% duty cycle under load at 3k rpm. I'm not really one to rev super high, but I think with a turbo I would definitely be pushing the injector. I could go for a larger flow one, but worried about poor idle control, and don't have a great (inexpensive) way of adding another injector like on the bagsport tb. I think i may be able to get away with just increasing fuel pressure?
Also I am planning to change out the speeduino for a rusefi uaefi board. Unfortunately the speeduino has no knock control, and before i go buy an external knock controller, it's basically the same money for a rusefi which would also be faster than the speeduino. Does anyone have any experience with the uaefi board?
Posted 16 August 2026 - 06:28 AM
The a series is incredibly noisy, so a knock sensor is difficult to tune in.
Posted 16 August 2026 - 06:47 AM
hm okay, changing to a 1000cc injector seems to be necessary then, although i would only be looking to run 5-7psi.
Steve, have you had any luck with running a knock sensor? I already have a basic bosch one, and just wired to an aux cord and amp that I can plug headphones into. Would be nice to have full knock based iginiton control though.
Posted 16 August 2026 - 03:02 PM
I ran a standard 998 head with twin gaskets for a while, it was absolutely fine. I think the metro run like 4psi to about 4k then the boost went up to 7psi. I believe it was done to avoid warranty claims and be a bit easier on the gearbox.
The best way to find your actual chamber volume is to measure it when you have the head off, anything else is just a guess.
For what it's worth if I was you I'd try twin head gaskets and go for about 7psi without an intercooler, or with an intercooler I'd run it up to 10 then go from there. As long as your fuelling and timing are safe you can keep developing things as time goes on while still enjoying the car.
Edited by lsto, 16 August 2026 - 03:03 PM.
Posted 17 August 2026 - 10:53 AM
I have, but the background thresholds are high! When i had my car mapped, my tuner induced knock at low rpm and moderate load to be able to hear and log it on the haltech nsp software. From there, the threshold is set to 3dB above background noise throughout the rev range. Its more of a 'just in case' of bad fuel, hot spot on the piston etc.
My analysis on the whole thing is actually listening to the engine during dyno sessions, let it tell you what its doing, and set the timing accordingly; creep up on it, rather than put in savage timing and wind it back.. youll save your engine that way!
Posted 24 September 2026 - 06:38 AM
Thanks to all of you for the valuable advice. I have since done tons more research and started ordering parts and tearing into the project.
You can follow me on instagram @cooperpooper.22 if you’d like to follow along with my progress!
Posted Today, 12:50 PM
Hello everybody!
Followed! Im turbocoopersport
