Piece Of Metal On Sump Plug
3 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 217 posts
  • Local Club: Mainly Minis Montreal
Posted Today, 12:06 AM
Hi fellas, today during an oil change I discovered a not so fun surprise, my sum plug seems to identify as a sparkplug! this piece of metal was on it. seems like a piece of a sort of ring. any ideas? how bad is this?
thanks for any advice.
#2 bpirie1000
bpirie1000
  • 2,549 posts
  • Local Club: Amoc
Posted Today, 06:19 AM
I would think that the gradual curve of that item would be to curvy to be a spark plug contact point.
From the non sized pic I suspect a crush washer or similar. Try looking at the rocker cover first and be systematic.
Get an exposed diagram of the engine and do what you can.
#3 nicklouse
  • 19,036 posts
Posted Today, 06:43 AM
A broken spring washer. A few should be in the gearbox.
#4 Ethel
  • 26,719 posts
Posted Today, 07:45 AM
It looks to have a deliberate ridge around the larger diameter that I don't think a spring washer would  have. It'd be worth patterning up with some washers though, see if it matches a 5/16 bolt hole & the thickness will be a hint.
