Can Anyone Identify These Plates?
2 replies to this topic
#1 DannyDS
DannyDS
    Just On Tickover
  • 7 posts
Posted Today, 10:52 AM
Hi.
I have these plates that have previously been welded into each bottom corner of my boot opening, can anyone shed some light on what the purpose of them might be / have been for?
Many thanks
Attached File  IMG_9253.jpg   72.25K   11 downloads
Attached File  IMG_9252 2.jpg   37.08K   9 downloads
#2 stuart bowes
stuart bowes
  • 2,588 posts
Posted Today, 12:04 PM
non-standard previous repair
welding in a narrow return / folded edge like that is tricky because the eges will just blow out every time you arc up
I would have either cut further back and welded in a new whole corner piece, either from a donor panel or by fabricating a new piece.  OR  weld in a wider piece to start with (so it can handle the heat) then cut it down afterwards
Getting the geometry right would take a bit of care and attention though (in terms of maintaining the 'shut' around the boot door) so it looks like instead of that they sort of bodged in a piece to the back side
depending on budget (and assuming the other side is probably in a similar state) it seems to me your best bet now is a new rear panel https://www.minispar...wer-half-mk2-on  (or whichever one suits your model correctly)
bracing up and cutting that out will also give you much better access to repair / replace the back end of the boot floor .  wheel arches look alright though to be fair, could be worse
Edited by stuart bowes, Today, 12:16 PM.
#3 Rubbershorts
Rubbershorts
  • 712 posts
Posted Today, 12:27 PM
Presuming that the area full of holes was packed with filler, the purpose of the plates was to probably stop the car twisting and the whole lot cracking and pinging out all over the place. Maybe. Daz.
Edited by Rubbershorts, Today, 12:52 PM.
