Honing Cylinder At Home?
5 replies to this topic
#1 Lenhamracer
Lenhamracer
  • 121 posts
Posted 22 August 2026 - 04:29 PM
Dear Mini friends
I have a problem with my cooper s engine. I took the engine out to swap the diff for a quaife and thought it might be good to have a look into the cylinders as I noticed a drop in the compression.
There are an lot of scratches and there are not many honing traces left. Also I found a lot of hard baked carbon.
It is time for a rebore but I a in a historic regularity rally in two weeks.
Do you think it is worth to rehone it with a drill and a honing adapter from amazon??
Unfortunately I don“t have enough time to rebore the engine and it ran like that at the last event and I thought a bit of honing is better than nothing...
Thank you and kind regards
Thomas
#2 Spider
  • 15,878 posts
Posted 22 August 2026 - 06:07 PM
In short - no. I did a bit of a write up on this a while back;-
http://www.theminifo...gine-machining/
#3 Lenhamracer
Lenhamracer
  • 121 posts
Posted 23 August 2026 - 07:40 AM
Thank you for your comment. I forgot to attach the picture..
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,568 posts
  • Local Club: Amoc
Posted 30 August 2026 - 02:48 PM
How much did the compression drop of late?
Might be a tell tale sign that things need to be 'Attended to
Depends how hard you drive it on the regularity rally.
#5 Lenhamracer
Lenhamracer
  • 121 posts
Posted Today, 09:27 PM
Sorry for the late answer...
Rally done and it was big fun! Engine was fine, I even managed to be 24th of 90 entrants in the steering wheel trophy (driving on closed tracks)! Today I started taking the engine out again. I found a lot of shaving on the draining plug magnet. Will attach a picture, any idea where they could be from? I will have a close look into the gearbox...
#6 Spider
  • 15,878 posts
Posted Today, 09:30 PM
Great result !
The 'fur' on the sump plug to me looks normal, it's largely from normal wear of the baulk rings.
