Recently I removed the brake master cylinder from my car to fix a fluid leak between the reservoir and the cylinder. More about that can be found here: https://www.theminif...itment-problem/
After installing the master back in the car I am now having problems in bleeding the brakes. There is not much pressure on the brake pedal: I am able to push it to the floor. When bleeding the brakes I notice that fluid does come from the bleeders at the drums in the back. However, there is no fluid coming from the bleeders at the calipers in the front. Nothing, not a drop. Neither from the left, nor from the right hand side brake. Also, when undoing the bleeder there is no change in feeling on the brake pedal. When undoing one of the rear bleeders you can feel the brake pedal having less pressure. Not so with any of the front bleeders. I have tried bleeding the brakes with both engine off and engine on: makes no difference.
I am wondering what might be wrong, causing this to happen? Any hints or tips on how to proceed with this?
