Renewing Inner Sills
3 replies to this topic
#1 johnno23
johnno23
  • 23 posts
Posted 25 August 2026 - 06:45 PM
hi guys, I,m about to replace the inner& outer sills on my MK1 mini. I intend to use the M-Machine panels. What I need to know is how far into the floor does sill panel extend onto the floor. I don,t need the one which incorporates the flutes as mine is solid from the bend to the flutes both sides ?
many thanks,
Johnno
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 25 August 2026 - 07:59 PM
Without going to the M Machine site i'm sure you can get either a inner sill to first flute or one that is just before.
A lot of folk like the combination of inner and outer sill as an assy, not my personal choice as i like to install them independantly. But i can also see the merit of them like that.
And just checked and you can get them before the first flute
#3 Ethel
  • 26,755 posts
Posted 26 August 2026 - 08:25 AM
Don't know if it's worth pointing out the inner sill left the factory as part of the floor pressing. The only "right place" is where you're not trying to weld rust.
A flat panel will be harder to weld without heat distortion.
#4 johnno23
johnno23
  • 23 posts
Posted 26 August 2026 - 03:10 PM
Thanks for replies, that,s the panel I am enquiring about, the one up to the 1st flute. The floor is sound up to there so all I need to cut out is about 1" from the upturn into the floor. I also prefer attaching outer sill seperately. So does any.one know how wide the floor section on the sill is into the floor
