Hi All
A newbie on the forum.
Have been working on cars for years but this is my first mini.
Currently replacing the upper and lower ball joint using the Minispares GSJ166MS kit.
Lower ball joint all good but...
Upper ball joint is loose even with no shims fitted.
Is their a oversized cup I can fit and where can I get one from?
Can I put a thin washer under the cup to raise it up so I can then add shims to make a good fit?
