Fitting And Timing New Distributor (Without Strobe Light )
3 replies to this topic
#1 JJanota
JJanota
    Starting My Mini Up
  • 3 posts
Posted Yesterday, 05:23 PM
Hi all,
after rebuild of 1275 A+ engine, I need now to time the new dizzy. Camshaft is a Evo002 and dizzy is an aftermarket recurved one ( 8 deg at 1000RPM ).
Problem is ... I don´t have the strobe light :)
Is there a way to start the engine and drive it to some garage for tuning there ? In a way that is safe for the engine ?
I was reading the artice from Keith Calver ( https://www.calverst...-ignition-kits/
 ) regarding the install instructions for his distributors and I got curious about this particular step :
´rotate crankshaft anti-clockwise (from front/coolant pump end) around 3/8”/10,0mm. Rotate distributor so the blade of the trigger is in the centre of the module. This will be around 8 to 10 degrees of static advance and will allow the engine to start and run so a strobe light can be used to set the correct/required ignition timing.
I guess that 1000 RPM will not be much higher than the typical idle RPM for my setup, right ? so, I think that by applying the above step I would be leaving the dizzy close to the required timing, allowing me to drive the car and take it to some garage for a more accurate tuning. Am I thinking correctly ?
Also, can I buy a Strobe light and do this at home ? Could you advise on something I could by on Amazon ? Do I need any other special tools for this ? Car does not have a rev counter, but I will install one and I was thinking to use it as the reference for RPM, in case I do it at home.
Many thanks guys,
I look very much forward to hearing see this engine running :)
#2 ADRay
ADRay
  • 142 posts
Posted Yesterday, 06:27 PM
yup, they sell timing lights at the local parts house that are suitable. I paid about $50 for mine and it works great. can’t speak to doing it without a rev counter though.
Edited by ADRay, Yesterday, 06:28 PM.
#3 68+86auto
68+86auto
  • 1,461 posts
Posted Yesterday, 11:30 PM
It can be timed to make it run but I'd just recommend buying a timing light. It is cheap compared to any engine damage from improper timing.
I use an Innova 5568. It has a tachometer and dwell meter inbuilt.
#4 Rubbershorts
Rubbershorts
  • 736 posts
Posted Today, 08:02 AM
Another vote for the Innova above. Another feature of it is the ability to measure how the distributor advances the timing. Daz.
