Brake Upgrade
6 replies to this topic
#1 TimNeal
TimNeal
  • 10 posts
Posted Today, 09:12 AM
Hi , I'm having an issue with my brakes
4 pot mini sport calipers
Pedal travel stops 2cm off the floor, brakes are operating but with out bite.
It's got newish pads & rotors.
I was reading on Mini sport website that there's a Cooper S specific master cylinder, same bore but taller by 15mm
With increased fluid capacity , so I assume (???) longer stroke meaning more "umph" in the system
Any advice to offer ?
#2 sonscar
sonscar
  • 3,247 posts
Posted Today, 09:18 AM
Pedal stroke is affected by relative diameters of pistons and cylinders relative to master cylinder bore,assuming adjustment and pad clearance is correct.This relationship also affects brake pressure.Larger volume of fluid will not help.Steve..
#3 mab01uk
mab01uk
  • 13,055 posts
Posted Today, 09:39 AM
The increased fluid capacity of the taller Cooper S/1275GT master cylinder was introduced because the brake fluid level can drop more quickly below minimum, with disc brakes as the brake pads wear, than it does with the earlier Minis drum brakes/brake shoes. If the brake fluid level dropped below the minimum level between checks/services air could enter the braking system...
Edited by mab01uk, Today, 09:42 AM.
#4 Ethel
  • 26,769 posts
Posted Today, 09:42 AM
If the pedal hasn't hit the floor a bigger reservoir won't help. The first thing that happens when you press the pedal is the piston passes the port connecting the cylinder to the reservoir so the fluid can't escape & has to transfer pressure to the calipers. A larger reservoir means a bigger reserve for when the pads wear down and the pistons move out creating more volume in the cylinders behind them.
Things to check:
Are the rear brakes adjusted & rear wheel cylinders not leaking?
Do your front wheel bearings have any play that's allowing the discs to wobble & push back the pistons?
Is there damp around or under the dust boot on the cylinder above the brake pedal, suggesting a leaky mastercylinder?
The front brakes do nearly all the stopping. If you can get a hard, not spongy,  pedal (travel doesn't matter) & assuming the pistons aren't seized in the calipers, it could well be the condition of the discs, pad compound being too hard or possibly contamination of the friction surfaces.
#5 stuart bowes
stuart bowes
  • 2,616 posts
Posted Today, 09:45 AM
what brake pads are you using (Ref 'operating but with out bite')
pedal travel, no idea, see other's comments  ⬇
Edited by stuart bowes, Today, 10:10 AM.
#6 Spider
  • 15,823 posts
Posted Today, 09:46 AM
They were never a good caliper, but, if they are new, the seals will be dry and so the pistons in them won't be self adjusting as they should. Remove 1 pad, chock 1 piston of the 2 exposed, pump the pedal about 4 - 5 times to move it out about 1/4", push it back in and move on to the next, doing all 8 pistons, This will lubricate them and you'll likely find the pedal will be higher.
#7 Ethel
  • 26,769 posts
Posted Today, 10:02 AM
We are assuming it's a single circuit setup, since you mentioned the Cooper master cylinder. If it's dual circuit a circuit may be out, leaking or just in need of bleeding. Spider could well be right about the poor performance, but I don't think it'd cause the excess pedal travel.
