Rebore Should Get Rid Of This Putting Right?
3 replies to this topic
#1 babsbrown
babsbrown
  • 592 posts
Posted Yesterday, 03:53 PM
Hey guys, just after a few opinions really.
Checked out my 1275 bores after been sat for 10 years. It's heavily pitted but feel as though I could get away with a 20thou rebore.
What's the general consensus. Seems a shame really, the other bores still have very visible honing marks. I just don't want to but +20 pistons for
It then to need a 30 or 40tho bore.
I appreciate I need a dial bore gauge to fully assess the situation and
I will measure everything fully when building but also a picture speaks a thousand words
Cheers, Babs
Edited by babsbrown, Yesterday, 03:55 PM.
#2 Spider
  • 15,830 posts
Posted Yesterday, 05:35 PM
You'd likely find that will clean up with a hone. You'll still likely see them, but as far as finish goes it'll be fine and really, f that's all there is of it, even if it doesn't make for a perfect seal, it's only in those few spots of the swept bore, you won't notice them. It would clean up with a rebore if you really wanted to go that way.
#3 babsbrown
babsbrown
  • 592 posts
Posted Yesterday, 06:54 PM
Thanks Spider, I was hoping you'd reply, I've always had great engine building advice from you before. At current the engine Is seized. I've filled the bores with penetrating fluid and ATF. I think I'll end up stripping it first rather than attempt to make it turn over. Last thing I want is to damage the crank unnecessary.
Glad it will clean up with a hone. I'd rather keep it 1275 as it gives me at least a few rebores left. I'll post up a pic of the cross hatching. I was quite impressed for an early ADO16 engine.
#4 Spider
  • 15,830 posts
Posted Yesterday, 09:27 PM
Thanks for the kind words and glad you've found it helpful. See how you go with the ATF and penetrating fluid, if in a couple of days, you don't have any luck there,then try diesel. Does sound link it wants a proper strip down though.
