12G940 Low Rpm Bog On A 998
4 replies to this topic
#1 Mini30BVA
Mini30BVA
    Starting My Mini Up
  • 4 posts
Posted Today, 10:47 AM
Hello all,
I've got a 998cc with flat top pistons, stage one kit and a 12g940 head. Everything is in pretty good condition, but I have a problem with low rpm bog. I know this is a common problem with the 12g940 head as the valves are bigger meaning air velocity is lower in lower rpms.
Is there any way to improve the low rpm bog? I've got an AAU needle in my HS4 carb, a 59d4 distributor with the advance set to what is suggested in the Haynes manual.
Is there anything I need to change or alter?
Thank you!
#2 sonscar
sonscar
  • 3,253 posts
Posted Today, 11:43 AM
When you say low bog what do you mean?flat spot exiting roundabout at 1500 rpm in third?slow to exit junctions in second?just asking Steve..
#3 whistler
whistler
  • 1,896 posts
Posted Today, 02:18 PM
Maybe try changing the damper oil to one slightly thicker.
#4 Mini30BVA
Mini30BVA
    Starting My Mini Up
  • 4 posts
Posted Today, 04:47 PM
Sonscar - It happens whenever I'm pulling away from stand still in the 800 to 2000 rpm range. Takes a bit to get going until about 2000rpm then its off like a rocket.
#5 Spider
  • 15,852 posts
Posted Today, 05:33 PM
The issue with the 12G940 on smaller engines is the Inlet ports are too big, as a result, at lower engine speeds, the flow rate through the ports is slow and so tends to change the state of the inlet charge from being atomised to a raw fuel and air state. You can make the car more drivable but selecting a needle that is considerably richer at these speeds, but it's not the best for engine life. Sorry, I don't have a needle recommendation here.
