Wont Go! Just Grinding Whirring Noise.
1 reply to this topic
#1 marcus550
marcus550
    Starting My Mini Up
  • 1 posts
Posted Today, 11:15 AM
I hit an expansion joint on the road, maybe 25mm high? Suddenly my 1992 Mini Mayfair ground to a halt, making whirring vibrating noises. I pulled over. Tried to go and it will creep, but any torque needed and it stops moving and makes grinding whirring noises. I thought I spun a CV, so pulled both drive shafts and rebuilt them. One pot joint looked mangled, so I thought - yes! Found it. No...it still does the same thing. Can something in the clutch fail like this? Or is it more dire?
#2 Spider
  • 15,865 posts
Posted Today, 04:03 PM
Hi and Welcome to the forum, though I won't make you happy here I'm sorry.
The first thing that comes to mind here is a broken diff. It would not have just happened from hitting that in the road, they do wear fairly quick in these cars and that would have been the last straw for it.
If you jack up the front end, you might get a feel for it by rotation the front wheels by hand, though ideally, if you disconnect the drive shafts and spin the pot joints from under by hand, you'll be able to get a better feel for it.
