No Power To Fuel Pump Mini Mpi
4 replies to this topic
#1 TheHunterHofman
TheHunterHofman
  • 52 posts
Posted Today, 12:44 PM
Hi all,
I have a 2000 Mini Cooper MPI Sportspack. After I had my block and head skimmed (after multiple failed head gaskets), I reassembled the engine and reinstalled everything. The car now won't start. I know that the fuel pump itself is working (bench tested it), but it won't go if I turn the ignition. The car cranks fine and I've checked all the connectors, cables and lines; everything is connected properly.
How could I easily check why the fuel pump is not going? You should hear it prime if you turn on the ignition, mine doesn't. I've also checked the feed line; nothing is indeed coming from the tank to the engine.
My knowledge of electrical stuff is very very limited. I have a multimeter, but that's it haha.
Thanks for any thoughts/help!
Best,
TheHunterHofman
#2 stuart bowes
stuart bowes
  • 2,635 posts
Posted Today, 01:54 PM
is there a fuse for fuel pump, on the mpi?  have you checked it if so
#3 TheHunterHofman
TheHunterHofman
  • 52 posts
Posted Today, 02:24 PM
Yes, that's good.
#4 stuart bowes
stuart bowes
  • 2,635 posts
Posted Today, 02:29 PM
I don't have an MPi .. but I guess the next thing would be to set your multimeter to volts, have the ignition switched on, and test the voltage at the fuel pump connector, see if there's 12v
fairly easy thing to check while awaiting others to come along with more detailed 1st hand knowledge
#5 lsto
lsto
  • 723 posts
Posted Today, 07:34 PM
Haven't accidentally tripped the inertia switch in the engine bay?
