I am renovating a relative's a 1991 Mini 1000 in IIRC Caribbean Blue metallic. After ill health stopped me from doing anything on it for over a year I've now got some capacity back. I'm keen to get it through an MOT so I can get it off my drive (my relative has no off-street parking and I have no garage). Both he and I want him to drive it for at least a short time and are loathe to sell it as it is. I have no-one here knowledgeable enough to bounce ideas off.
I'd sorted all the rust on the main shell and had broken the back of the electrics and mechanicals. I'm therefore not expecting any great difficulty in finishing those. However, I'm in a quandary over what to do with the rust on the doors. The offside door, the one still on the car, has mainly fillable holes, the nearside door, the one off the car, has more serious rust and the bottom of the front panel has a lot of rust damage. If I can help it I don't want to chuck loads of my relative's money at new doors or replacing panels with the attendant paintwork. Better, perhaps, to put off the decision on spending loads of money by using lots of Belzona Liquid Metal and body filler to get it done with the least cost and effort now.
My understanding of how the MOT Manual applies is as follows:
- Appendix A: Structural Integrity and Corrosion: the doors are not in a prescribed area so defects should only be rejected if either braking or steering is adversely affected due to structural misalignment or the strength or continuity of the overall vehicle structure is significantly reduced. I think this won't be an issue.
- Section 6. A body panel or body component damaged or corroded and likely to cause injury when grazed or contacted, or insecure is a Major (ie MOT failure). This is will dictate the rust be repaired to avoid injury.
Section 6.2.3. Security and opening. Both doors lock and open as advertised so this should not be an issue.
I attach some images of the doors and sills.
Please can someone advise me on what may be the best things to do?
