Hi all i have a 1992 mini cooper SPi which has Squeak on drivers side front, which show's it self under acceleration / deceleration. I have checked both top and bottom engine stabilisers and they feel solid and the engine does not seem to move when I try to rock it by holding on to the manifold. I had to change the Steering column bushes as their was a lot of play in the column. I have checked the steering rack and that seems solid as well. I suspect that although the stabilisers look ok, they are old. check the dash and it does not seem to move either.
Any one had the same and can give advice.
