Hi all, Fitting rear Inertia sea belts to a classic Austin mini 1000. Does anyone have any pictures of their installations for guidance. Cheers
Posted Today, 04:08 PM
Posted Today, 07:07 PM
Posted Today, 07:21 PM
im not well versed on all the models and variations but somerford mini do all the relevant parts:
you'll need to be sure of what year your shell is, and make sure you get whatever your car doesnt have fitted already, for the right model
https://www.somerfor...abriolet-100736
relevant parts would *something like* but not necessarily the kit numbered 67 in the box near the top (or the plates by themselves as seen top left no 65) are where the top belt pull-through part gets bolted on
and the brackets that go in the rear seat side bins, numbered 48 in the middle, welded on the the wheel arch, are where the actual spools get bolted on
don't order those exact parts but at least click on them and have a look at them so you can see roughly what you should be trying to achieve and compare that to what you have fitted (i.e. do your C pillars have those inner plates fitted with a threaded bolt hole in the same place.)
specifics will vary depending on year as mentioned. pics of what you currently have would help, or give them a call and speak them about it to see if you can even fit those to your model (possibly not)
I think there are other kits where the spool is fitted on the shelf but I don't have info on those
Edited by stuart bowes, Today, 07:27 PM.
