Repeater indicators
spud
, Nov 27 2006 12:37 PM
11 replies to this topic
Posted 27 November 2006 - 12:37 PM
Hello,
I've learned recently that my '92 Mini needs repeater indicators in the front wings, so I have bought all the necessary fittings to do the job because the wings that were fitted by the previous owner do not have the necessary holes > .
Could someone please tell me
1) Where exactly do I need to make the holes? (Just in case I change the arches in future)
2) What shape and size do they need to be? (At worst I could work it out from the light fittings)
As usual, any help would be appreciated,
spud.
spud.
Posted 27 November 2006 - 01:05 PM
that should help with the where
and from what i can remember the holes are square
Posted 27 November 2006 - 01:08 PM
yep holes are square as for dimensions im not sure
Posted 27 November 2006 - 01:12 PM
you can put whatever indicators in that take your fancy
Posted 27 November 2006 - 01:36 PM
Yea, you can put them wherever you like, even on the A panel (although make sure they conform to MOT rules about being visible from certain angles - MOT manual in FAQ section). You may need to adapt the wiring loom supplied with them if you put them somewhere different to standard.
Posted 27 November 2006 - 03:22 PM
Make a template outta cardboard. Make sure the side repeaters fit this whole. Then you just gotta position them right.
Posted 27 November 2006 - 03:24 PM
Thanks for the replies y'all.
The info gives me a good starting point which I will probably go on, however, I am concerned that in future I might fit the wider arches that I've seen somewhere which have a recess at the top of the front arch and it would look a bit daft if I'd put the indicator an inch (25.4mm to you young 'uns) or so too high or to one side!!
Cheers,
spud.
Cheers,
spud.
Posted 27 November 2006 - 09:01 PM
I like the focus indicators, especially on clubbies
Posted 28 November 2006 - 11:41 AM
Could someone please tell me what the measurement is between the top of the front wheel arch and the bottom of the repeater lens - then I can position the hole accordingly?
It would be appreciated, cheers,
spud.
spud.
Posted 28 November 2006 - 10:39 PM
Would anyone like to guess?
Cheers,
spud.
Cheers,
spud.
Posted 28 November 2006 - 11:31 PM
I might well still have the bits i chopped out of my old wings.
i have a 93 and wings with no holes in and need to do the same as you.
i chopped a bit out of each side with the wheel lip still on and lined it up and marked it that way.
will look in the shed tomorrow to see if i still have them.
if not i will try and do a templte for you of my wings!!
Posted 29 November 2006 - 09:03 AM
Cheers Dude
That would be very much appreciated!!
spud.
spud.
