A Simple Tip For Checking Tyre Wear
No replies to this topic
#1 cedricvale
cedricvale
  • 17 posts
Posted Today, 01:17 PM
Uneven tyre wear can tell you quite a bit about how a classic Mini is running.
When checking the tyres it is worth looking across the full width of the tread rather than just checking the outer edge. Wear on one side or in the centre can be a sign that tyre pressures or wheel alignment need checking. Also look for cracks and bulges in the sidewalls as these can be more serious than normal tread wear.
If one tyre looks noticeably different from the others it is worth investigating rather than just replacing it and ignoring the cause. checking the pressures regularly and keeping an eye on tread wear can help spot problems early.
