A little question
Posted 10 December 2006 - 01:05 PM
Having noticed a significant oil leak from under my 998 auto I have hopefully pinpointed the problem to a missing gearbox to block bolt. It's one which is really difficult to get to -just above the passenger side inner CV joint in the corner next to the timing gear cover.
Could anyone please tell me what thread type this missing bolt is and how long it is? It's so that I can obtain one locally and hopefully cure the leak.
Cheers,
Spud.
Posted 10 December 2006 - 01:09 PM
Hi,
Cheers,
Spud.
if that is the case i think you will have to fit a new gaskrt to cure the problem
Posted 10 December 2006 - 01:28 PM
Though not the answer I was looking for
I am planning on upgrading to a 1275 manual sometime next year and was hoping that the present set up would last til then.
Is it worth a try with a new bolt?
Cheers.
Spud.
Posted 10 December 2006 - 01:37 PM
Cheers.
Spud.
yeah it's worth a try mate. it will certianly make it leak less even if it doesn't stop it.
Posted 10 December 2006 - 01:38 PM
Cheers,
Spud.
Posted 10 December 2006 - 02:26 PM
Does anyone know what thread and length it is as I'm led to believe that some threads on the engine are UNF and some are UNC?
Cheers,
Spud.
try to take another bolt/nut off and get one the same
Posted 10 December 2006 - 02:36 PM
also the leak could be coming from the pot joint seal itself, just an extra thaught for you
Edited by cowboy, 10 December 2006 - 02:49 PM.
