Could someone tell me is it an engine out job to change the clutch on a mini?
clutch
blakie
, Dec 11 2006 12:32 AM
6 replies to this topic
Posted 11 December 2006 - 12:32 AM
Posted 11 December 2006 - 12:41 AM
it isnt an engine out job to change the clutch in a mini!!
it aint easy tho!!
personally i can remove an engine and chnge the clutch faster than i can change the clutch with the engine in situ!! but i guss that may be down to lack of practise!!
it aint easy tho!!
Posted 11 December 2006 - 12:43 AM
ive never done either so both will be hard!!!
Posted 11 December 2006 - 01:25 AM
haynes manual may help you
Posted 11 December 2006 - 11:26 PM
Hi, without removing the engine, it will be tedious, however it is possible! It involved undoing the offside engine mount from the subframe, and also loosening the other one, as I would do.
Then jack up the offside end of the engine. The Haynes manual goes into much more detail however.
Youe biggest problem I think will include getting to the clutch cover retaining bolts, and after the clutch replacement, replacing them!
The actual clutch replacement itself is only made difficut by the removal of the flywheel. Once this is off, the rest is straightforward.
But read the haynes Manual. If anyone tells you this is 3 hoiur job, dont listen to them. Taker your time, as you might find that leaving a whole weekend would be wise!
PM me, and I will give you my number to call. I did a clutch out job on my mini 2 months ago.
Edited by mk=john, 11 December 2006 - 11:28 PM.
Posted 12 December 2006 - 12:22 AM
Cheers guys, im kinda thinking of poping the engine out and replacing the 998 with a bigger lump, and what the hell tidy the whole car up while its off the road! any ideas what to do with him? gotta keep the lovely choclte brown of corse
Posted 12 December 2006 - 01:53 AM
non mg 1300 from a breakers????
