Oil Filter Housing for 1995 Auto
northern_paul
, Dec 12 2006 04:34 PM
6 replies to this topic
Posted 12 December 2006 - 04:34 PM
Helloo all - I'm having a lot of problems locating the following part Oil Filter Housing 37H1480 - it's for a 1995 auto and my 'steeler' says the part is obsolete!!!!!
Any idea's????????????????
Posted 12 December 2006 - 04:43 PM
hold on, what do you mean oil filter housing. The only thing that I can think of is the mk1 oil filter things with the paper element.
If I might ask could you divulge more infomation on said part?
Either that or wait for someone smarter than me to come along.
Posted 12 December 2006 - 04:56 PM
Yep, all auto's have the paper type filter.
Is the housing (by which I guess you mean the canister that holds the paper element) knacked then, as it's only the inside that needs changing?
If so, and our sponsors can't help then fleabay I guess.
[EDIT: This what you're after? ]
Edited by Garagiste, 12 December 2006 - 04:59 PM.
Posted 12 December 2006 - 05:28 PM
No - it's the right angled ally casting that attaches the canister to the gearbox (auto) - the car has had a little front end bump and I've bought it for my wife for xmas - it arrived today and removed the damaged panels - subframe wasn't touched but both the alternator and the oil filter housing were cracked - that pic is similar but mine is bigger (phanaaaar phanaaar, phinbar saunders lives!).
Posted 12 December 2006 - 05:43 PM
The bolt pushes in and tightens up to keep the oil filter on.
Think he means the thing in between the filter and the engine.
Edited by minibob, 12 December 2006 - 05:44 PM.
Posted 12 December 2006 - 05:50 PM
Bob - that's the filter - the other end of the canister is a ally casting (the bolt will screw into it) and this casting is cracked - Stockton eh, I'm originally a Darlington lad but now live on south coast - english riviera ha - been pishing down for weeks now!
Posted 12 December 2006 - 08:46 PM
If no one sells a replacement auto oil filter head you could buy an old broken engine for spares. Could try eBay, there is a few auto engines on there like Item number: 250059156828 the next question would be if the filter head changed over the years and between the different size engines! It’s an idea.
