melted wire
mini16
, Dec 12 2006 07:24 PM
5 replies to this topic
Posted 12 December 2006 - 07:24 PM
hi, there is a red wire what goes into a connector which connect to the back of my 3 dial cluster, well it seems to have melted, how could this be caused and what wire is it for, its melted all onto the connector.
Posted 13 December 2006 - 01:40 AM
dont know about whats caused it but it shud be the power supply to the rev counter!! check to see if anything has rubbed thru to it!! if it contacts the shell directly that could do it!!
if its sitting unused and your rev counter is powered by a green/orange wire then it coule have dangled free and touched something but it shouldnt be needed!!
can u show a pitcure of it?
Posted 16 December 2006 - 10:03 PM
just took a closer look and its numbered 9, heres a pik if you can make it out
Posted 17 December 2006 - 04:57 PM
actually looks more like its the sideligts supply to the clocks!! as for why its melted!! stil psuspecting a bad earth or broken wire touching bare metal somwhere!!
Posted 18 December 2006 - 02:38 AM
Check where the wires pass through the bulkhead. Sometimes they can chafe on the air-filter housing and cause a short.
Posted 18 December 2006 - 08:58 AM
I think i have one of those plugs if you want to replace it
is the clock side ok ? pm me if you want it
