Could someone tell me the difference between a solid state facet fuel pump and a red / silver top fuel pump? apparent differences:
FACET FUEL PUMP COMPETITION SILVER TOP has 30 gph 1/4" fuel line
FACET FUEL PUMP SILVER TOP has 18 gph 1/4" fuel line
FACET FUEL PUMP RED TOP FOR 5/16" FUEL LINES 40 gph will require 5/16" fuel lines
FUEL PUMP FACET FAST ROAD SOLID STATE PUMP 18 gph
FUEL PUMP,FACET "STD" SOLID STATE PUMP 12 gph
FUEL PUMP COMPETITION SOLID STATE FUEL PUMP 25 gph
What are the intended applications of a "top" pump and a solid state? Do they work in different ways? What is the standard size of fuel line? Finally which would be most suited to a 1380 with a 45 weber carb? Thanks
Fuel pump
robson
, Dec 13 2006 02:49 PM
8 replies to this topic
Posted 13 December 2006 - 02:49 PM
Posted 13 December 2006 - 04:50 PM
gallions per hour are diffrent.
psi is what you need to look at (I think) the lowest raceface one is 3psi which is about what you want for standard. BUT! you have a bigger meaner engine so you should get the slightly higher psi one with a fuel pressure regulator that way you can tone it down a bit and stop petrol pissing out all over the shop.
on the solid state front, somthing to do with the way it's driven I believe.
Posted 13 December 2006 - 11:41 PM
Solid-state fuel pumps imply that they can be controlled via pulse width modulation. ie a square wave could be sent to maintain say, 50% duty cycle.
They also need a filter pre-pump.
Posted 14 December 2006 - 11:20 AM
If its driven by pwm, how come there arent any controllers for them? with a regulator, is there a limit to how much they can regulate? ie could i stick a 40 gph and limit it to 20 if i wanted? Which pump is most suited to a 1380? Thanks
Posted 14 December 2006 - 07:58 PM
my facet solid state pump just runs at a consatnt speed!! maybe it is controlled by a pulse with modulator but it must all be internal!! the speed does not vary when the pressure rises!! it works the same way as a std mini mechanical item, runs 100% of the time just doesnt pump over a certain pressure!!
that may sound confusing!!
the cylindrical types are pressure regulated as they slow when the pressure gets to a certain point!!
Posted 14 December 2006 - 08:07 PM
do you need to run a return from the regulator to the tank though to stop huge pressure build ups??
Posted 14 December 2006 - 08:16 PM
nope the pump will only put out a certain pressure then it will operate but not pass any pressure!! seriously the same way a mechanical one works! just electronic and smaller!! tho ideally you get it for the size of engine you have!!
its called solid state i think because its a solenoid(electro-magnetic) and spring and its contorlled by a clock pulse electronically!!
it will only be able to pass as much pressiure as the spring will push!! once its reached the pressure the 1 way valve holds the pressure til the carb uses it and the pressure holds the spring up!!!!
that help??
you can run a bigger pump and put it thru a pressure regulator tho!! thats what im doing!! soild state pump rated upto 150bhp and im only looking for 70 - 80!!
that help??
Posted 15 December 2006 - 12:59 PM
thats cleared that up for me however why are there solid state types and can types? what is the application for each?
Posted 15 December 2006 - 02:24 PM
i dont think solid state ones are capable of flowing as much!! i really dont know tho!! have seen both on a race car!!!
