Rear subframe weight
41 replies to this topic
#1 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 14 December 2006 - 01:22 AM
Can anyone tell me the complete weight of a rear subframe with hubs drums radius arms shocks etc
#2 MRclubman1100cc
MRclubman1100cc
  • 139 posts
Posted 14 December 2006 - 03:17 AM
hey mate, i just finished striping one of my minis and the rear subframe with all the conponents on it weights very little, i can pick it up no worry's im guessing it about 60-65KG. the front subfames weight about the same.
#3 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 14 December 2006 - 06:19 PM
You must be he-man! LOL. I removed my rear sub complete and wouldn't have described it as weighing very little compared to the alumnium beam replacement (which i could lift with my little finger). I'd say the same weight wise, but perhaps nearer 70-75kgs.
#4 *DJH*
*DJH*
  • 4,972 posts
Posted 14 December 2006 - 06:23 PM
A Full Rear Subframe 70-75Kg? Really! Blimey I Didn't Think It Was That Heavy, When I Did It To Mine I Moved It Around With One Arm And Put It On The Car Myself...
Honestly That Has Shocked Me... :D
Edited by DJH MINI MOTORSPORT, 14 December 2006 - 06:24 PM.
#5 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 14 December 2006 - 06:25 PM
If people are describing them as weighing very little and that you can pick it up with one arm, i wouldn't say they weighed 60-75 kgs...unless of course, you are both He-Man? But i think that is technically impossible...?
#6 *DJH*
*DJH*
  • 4,972 posts
Posted 14 December 2006 - 06:29 PM
Yeah, I Would Have Placed It In The 45-55kG Catagory. Who Know's.
Koss And DJH - TMF HE-MEN :D
Edited by DJH MINI MOTORSPORT, 14 December 2006 - 06:30 PM.
#7 Jammy
Jammy
  • 25,397 posts
Posted 14 December 2006 - 06:35 PM
Well I know the subframe weighs 14kg. Each radius arm is about 8kg I *think*, the hubs must be about 4-5kg?
#8 *DJH*
*DJH*
  • 4,972 posts
Posted 14 December 2006 - 06:47 PM
Now You Break It Down Like That, It Does Make Sence. :D
#9 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 14 December 2006 - 06:59 PM
Yeah I've been piecing it together from various literature and I think I've really over estimated. Jammy is spot on with 14kg for the subframe, 8kg for each trailing arm and probably 5kg ish for each hub so we're looking at 40kgs all in 45kgs max with shocks etc.
Edited by Alburglar, 14 December 2006 - 07:02 PM.
#10 Jammy
Jammy
  • 25,397 posts
Posted 14 December 2006 - 09:28 PM
I'm saying an easy 50kgs once you've got the drum brakes fully assembled and grease in the radius arms, etc.
#11 R1mini
R1mini
  • 1,387 posts
Posted 14 December 2006 - 09:48 PM
I agree with the 14kg for bare subframe, a complete built up radius arm with hubs, brakes, etc with the spacered drum is 14kgs each, fairly accurate as I have just weighed it now
So that is 42kgs, then you have the shockers, rubber suspension, cones, ball joints which must be another 10kgs, so 52kgs is my best guess
What are you up to Koss?
PS When I swapped a standard subframe setup to the minispares alloy beam, minifins, protech coilovers I saved about 22kgs off the backend
David
#12 Jammy
Jammy
  • 25,397 posts
Posted 14 December 2006 - 09:56 PM
You put ball joints on the back? Oh yea, your special aren't you!
Surely if your putting ball joints on the back your not using a rear built subframe..
#13 R1mini
R1mini
  • 1,387 posts
Posted 14 December 2006 - 09:58 PM
I couldn't remember the name of that ball thing, but now I remember now, the knuckle joint
I decided to edit my response, not because of you Jammy, but because I don't want to offend sensible folk on this forum
If you have nothing constructive to say just be quiet
David
Edited by R1mini, 14 December 2006 - 11:47 PM.
#14 koss
koss
  • 1,399 posts
Posted 15 December 2006 - 06:29 AM
:gimme: So about 50kg I know when i took it off i could'nt lift it just drag it across the floor so i guess i must be a weekling
any way just some hollow alloy cast radius arms and an alloy beam :crazy:
#15 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 15 December 2006 - 08:33 AM
Perhaps one of them is the animated He-Man and one of them is Dolph Lundgren? Either that or one of them is She-Ra??? :gimme:
My guess (seeing as we are playing guessing the weight of a rear subby) is around 50kg's
