Rear subframe weight
41 replies to this topic
#31 Jammy
Jammy
  • 25,397 posts
Posted 25 February 2007 - 06:09 PM
Actually, I've just thought, it hasn't got rubber cones, trumpets, or dampers on!
#32 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 25 February 2007 - 06:12 PM
weigh em seperately and post em up someone!
I will have a complete rear subby off the car next week, which I can also weigh, I also have a built engine and box, a front subby with hubs and discs and loads of other stuff off the car. Might weigh it all at some point!
#33 *DJH*
*DJH*
  • 4,972 posts
Posted 25 February 2007 - 06:13 PM
Bloody Hell James, How Did You Miss Those!? :wub:
O.k. How About.......35 K.G.
Edited by DJH MINI MOTORSPORT, 25 February 2007 - 06:13 PM.
#34 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 25 February 2007 - 07:12 PM
I am sure the weight was mentioned in vizards first book or was it clive trickeys.
#35 Jammy
Jammy
  • 25,397 posts
Posted 25 February 2007 - 07:37 PM
Right, well I weighed it in at 45kg. So once you add the rubber cones, dampers and trumpets, I'd say it would be between 50-55kg.
#36 Mini-Dave
Mini-Dave
  • 509 posts
  • Local Club: SMAG
Posted 25 February 2007 - 07:51 PM
while were all being weight weeneys :crazy: , how much do those alloy rear beams weigh ? if a subbys 16kg or whatever it was you said!
:wub:
I like the idea of just cutting the rest of the rear sub frame off tho, and just leaving the bit that sits up against the heel board ?!?!??!!??!?!
Dave :angel:
#37 $way
$way
  • 720 posts
  • Local Club: ...
Posted 26 February 2007 - 09:19 PM
this is exactly what i have done.
#38 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 27 February 2007 - 07:59 AM
I don't think tha Mr MOT will be too happy with putting his name to a car fitted with such a heavily modified subframe as that :dozing:
#39 Mini-Dave
Mini-Dave
  • 509 posts
  • Local Club: SMAG
Posted 27 February 2007 - 01:23 PM
well to be honest its its not much diff than the alloy beam ?! if anything i would have thought it would be stronger, like the bit in the middle where its drilled, that bit cant take much stress surely as its bolted either side of the radius arm ?? im guessing your putting extra mounting bolts /brackets in sway?
Dave
#40 *DJH*
*DJH*
  • 4,972 posts
Posted 27 February 2007 - 01:42 PM
Yesssss, Get In There! :dozing: I Said 46KG.
#41 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 27 February 2007 - 06:52 PM
to be honest i think the bulk of the weight is in the radius arms and drums plus the full rear sub gives the rear end a fair bit of strength!
#42 $way
$way
  • 720 posts
  • Local Club: ...
Posted 27 February 2007 - 07:22 PM
I don't think tha Mr MOT will be too happy with putting his name to a car fitted with such a heavily modified subframe as that dontgetit.gif
we'll have to wait and see :dozing:
true
yes, it has two m10's bolted through the frame into the heelboard with spreader plates. this will be plenty. the MS alloy box section doesnt use any extra mounts!
