Who's fitted a Revotec fan
25 replies to this topic
#1 Maxmini
Maxmini
  • 308 posts
Posted 14 December 2006 - 08:09 PM
Who's fitted a Revotec fan to their mini with a std clubman front , I believe you have to fit the fan inside the wing and also the fan sucks out the hot air is this right.
Any pictures would be great and details of the brackets to hold the fan . Tryed to fit the fan to the rad but their is no room between the rad and cowling.
#2 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 14 December 2006 - 08:11 PM
isnt the fan marked with the direction of flow? cant comment on the revotec other than to say dam im glad i got a kenlowe!!
i think i've posted to sum1 before that removing clubman radiator brackets(top and bottom) and fitting round nose ones gives you nearly an extra inch to play with!!
#3 Maxmini
Maxmini
  • 308 posts
Posted 14 December 2006 - 08:31 PM
Nice one fikus 01 yes like you said I will have to get the brackets it does have direction of the fan and I gave it a spin and it sucks. Is it better to have it blowing onto the rad.
#4 fikus01
fikus01
  • 1,910 posts
Posted 14 December 2006 - 08:33 PM
afriad not, suck thru fans are more effective,
#5 Maxmini
Maxmini
  • 308 posts
Posted 14 December 2006 - 08:40 PM
This one does suck but do you still run with the engines plastic fan as this sucks to but it is drawing air in and the electric fan is pulling air out.
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 December 2006 - 08:43 PM
the rover coopers have 2 fans
the engine driven one to push air into the fan and the electric fan (fitted in the wheel arch) to suck air out
#7 Ollie180
Ollie180
  • 2,781 posts
  • Local Club: Sasmog.co.uk
Posted 14 December 2006 - 08:45 PM
i have 2 fans like bungle said one off belt and ive stuck a metro one other side of the rad under wing and turn it on if she gets a tad lil hot and it work a treet!!!! you see the temp gauage drop after a while :D
#8 fikus01
fikus01
  • 1,910 posts
Posted 14 December 2006 - 08:48 PM
suck thru alone is more than enuf!! i often wonder how much of the minis development was halted because they were afraid to change it in case they put of the purists!!
#9 Maxmini
Maxmini
  • 308 posts
Posted 14 December 2006 - 09:20 PM
So you mean remove engine fan and have the fan on all the time fikus01.
#10 Ollie180
Ollie180
  • 2,781 posts
Posted 14 December 2006 - 09:25 PM
wont a electric fan burn out if you use it all time?
#11 Maxmini
Maxmini
  • 308 posts
Posted 14 December 2006 - 09:54 PM
Thats what I thought lol.
#12 Ollie180
Ollie180
  • 2,781 posts
Posted 14 December 2006 - 10:01 PM
could you not fit a sensor to the temp gauge off the engine so if reaches 90 to switch itself on?
#13 Maxmini
Maxmini
  • 308 posts
Posted 14 December 2006 - 10:02 PM
Have you taken out the plastic fan fikus01 to fit the electric fan inside the inner wing, or just fit with the new brackets and thats it i.e in a std clubman front.
Edited by Maxmini, 14 December 2006 - 10:04 PM.
#14 fikus01
fikus01
  • 1,910 posts
Posted 14 December 2006 - 10:33 PM
no my fan works the sam way a conventional cars fan does!! only on when its needed!! did u look at my pictures?? no plastic fan either, just cut out a little bit of the rad cowling to aid airflow into the rad at speed!!
#15 Ollie180
Ollie180
  • 2,781 posts
Posted 14 December 2006 - 10:36 PM
mine.. duno if ne help to you
have fan off belt pushing air thru and elctric fan sucking it away! abd blowing it out
Edited by Ollie180, 14 December 2006 - 10:37 PM.
