after reading posts on similar problems had a look at the mountings.
the lower steady on the right hand side was a bit loose so i tightened that.
the steady under the radiator seemed fine.
then to my horror discovered that the upper steady, though still attatched to the engine, had ripped clean away from the torn bulkhead mounting. I lifted it back into place and the engine weight held it tightly in position (see photo). The engine had been easily rockable before and seemed tighter now.
I read that someone had welded the mount back together. It looks a little rusty so i wondered whether it would be better to replace it. Is this difficult and where is the best place to get the parts.
I don't anticipate repairing this will be the end of the problem from previous posts!
thankyou for any advice you may have.
