indicator woes!
27 replies to this topic
#1 Clubby1275GT
Clubby1275GT
  • 1,176 posts
  • Local Club: Birmingham Mini Owners Club / Bruuuums Mini's
Posted 18 December 2006 - 10:06 AM
I thought i had sorted all my electrics back in the summer, it sppears not!!
right here is the problem
indicate right - back indicator stays permanently on and instead of the front indicator going on the front sidelight comes on (with lights off-with lights on it goes off - clubman!)
no interior indicator light for turning right either.
when i put my hazards on all hell breaks loose! the left hand side is fine but the sidelight flashes instead of the indicator! the bulb is fine as i changed it and it made no difference, this makes me think its an earth!
but where is the earth for clubman sidelight/indicators?? or could it be something else???
#2 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 18 December 2006 - 10:20 AM
Try running new earths to the rear light clusters it sounds as tho you have no earth on the rear o/s light. The current will try and seek an earth usualy through the side lights hope that helps if it makes any sence
Edited by koss, 18 December 2006 - 10:21 AM.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 December 2006 - 10:24 AM
As Koss says, sounds like an earth leak... unfortunately, can be a right royal pain to find
#4 koss
koss
  • 1,399 posts
Posted 18 December 2006 - 10:48 AM
Just a tip Buy a little test light from a car shop (brass ones £2) take the bulb out of the test light and replace it with a piece of metal, or wrap the bulb in tin foil and replace it. This makes a good earth probe. Clip the croc clip to a nice clean bolt inside the boot area. Then switch your indicator on. With the pointed end of the probe pierce the black wire on to indicator light. IF it starts working correctly, That is the earth to be replaced. If not repeat on the front indicator
PS mind your fingers with the point
#5 Clubby1275GT
Clubby1275GT
  • 1,176 posts
Posted 18 December 2006 - 11:01 AM
so because the front indicator doesnt work at all, it must be the rear lights earth?? doesnt seem to make sense!
when u indicate the rear light stays on but the front light doesnt come on at all, instead the sidelight goes off/goes on (depending on if lights are on)
when u put hazards on the rear indicators work fine, but the front drivers still doesnt come on, instead the sidelight flashes!
#6 koss
koss
  • 1,399 posts
Posted 18 December 2006 - 11:09 AM
Sorry misread your first post do the same to the front then.
Just follow the black wire from the front indicator back that is your earth
Edited by koss, 18 December 2006 - 11:14 AM.
#7 Clubby1275GT
Clubby1275GT
  • 1,176 posts
Posted 18 December 2006 - 11:56 AM
its weird really, id have thought if it was the front earth then why wouldnt the back flash and the interior indicator light flash too?
maybe its linked, ill have a butchers after work!
#8 koss
koss
  • 1,399 posts
Posted 18 December 2006 - 12:05 PM
The flasher relay wont flash if you take a bulb out it needs 2 to complete the circuit resistance or load on the flasher relay must be right.
Edited by koss, 18 December 2006 - 12:06 PM.
#9 Clubby1275GT
Clubby1275GT
  • 1,176 posts
Posted 18 December 2006 - 04:51 PM
so that means it must be an earth then!?!?!
#10 koss
koss
  • 1,399 posts
Posted 18 December 2006 - 04:53 PM
yep
#11 Clubby1275GT
Clubby1275GT
  • 1,176 posts
Posted 18 December 2006 - 05:14 PM
brings me to my next question! to save rumaging around in the dark does anyone no where the sidelight/indicator earth is on a clubman?
#12 Clubby1275GT
Clubby1275GT
  • 1,176 posts
Posted 19 December 2006 - 10:13 AM
didnt get chance to look last night but this morning noticed more problems!!!
with the headlights on if u go to flash them, they go off!! and if u go to put the main beam on they go off!!
hmmmmm are they linked?? is it all one earth?
#13 Clubby1275GT
Clubby1275GT
  • 1,176 posts
Posted 19 December 2006 - 12:22 PM
#14 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 19 December 2006 - 04:40 PM
Sounds like a dodgy stalk to me?
#15 dying2live06
dying2live06
  • 160 posts
Posted 19 December 2006 - 04:46 PM
oh dear sounds like great fun gud luck
