Oil in head ports
Posted 18 December 2006 - 05:42 PM
I have driven it about 20 miles max and it's smoking really bad when driven, it is oily blue smoke. It is using loads of oil too (about 4 litres) in those 20 miles.
I had the head skimmed and ground in the valves and put on new stem seals aswell.
My first thoughts were knackered piston rings, but i have just removed the manifolds and there is oil in the inlet ports in the head and it looks like possibly in the exhaust too but has been burnt off.
Any ideas what's wrong?
Posted 18 December 2006 - 05:52 PM
Your valve guides are completely knackered
you have a bust head
And 4 litres in 20 miles, make sure you havn't got a hole in the sump !
Posted 18 December 2006 - 05:56 PM
Also, when the head was skimmed, was it pressure tested? Is there more oil in one inlet port than the other, or are both equal?
As GW said, the oil consumption may not be just down to the head, to have used that much you may have oil leaking out somewhere!
Posted 18 December 2006 - 06:13 PM
As others have suggested, if the guides were badly worn, you've wasted your time and money lapping in the valves. The guides and valve stems need to be in good shape to justify the lapping. With new seals though I wouldn't expect even the worst worn guides to account for the volume of oil you're loosing.
It could be a combination of faults causing your problem. Add to the list you already have to check your PCV valve/system. If it's allowed to pass vacuum all the time, and if your rings are shot and the engine has lots of blow-by, you could be getting a fair amount of oil drawn into the intake manifold like you're seeing. Still, I don't think that alone explains what you're experiencing.
Posted 18 December 2006 - 06:22 PM
Posted 18 December 2006 - 06:28 PM
Oooh, showing your age a bit there DK. The PCV valve was ditched years ago and the brethers have been permantly connected to vacuum for a very long time now.
Trying to lap unleaded valves and seats by hand is pretty futile anyway I'm lead to believe, they're far harder than the grinding paste is. Three angle cutters are needed to clean the seat up properly.
Posted 18 December 2006 - 10:11 PM
No PCV... what is the world coming to?
Posted 18 December 2006 - 10:17 PM
Posted 18 December 2006 - 11:26 PM
The engine oil was drained then i put in about 4litres and it was left overnight and then the disptick read about halfway between max and min. now after running it for a bit it doesn't even register on the dipstick?
The timing cover breather is connected to the carb and the crankcase has a breather on it. i modified the timing breather to clear the duplex chain, do you think the inlet could be sucking oil out from here? It was smoking excessively when you put your foot down and a little at idle.
Any ideas what to do about this? I was going to take the head off and have it pressure tested, to rule out any cracks in the head? then have new guides fitted if the pressure test was ok, is this the best place to start?
Posted 19 December 2006 - 12:24 AM
Doesn't take all 4 litres to go for the oil to disappear off the dipstick. It's about a litre from the bottom of the dipstick to the mid point I think and remember that a good half litre will have disappeared into the engine's guts after an oil change. Stick half a litre in and I think you'll find out that you haven't lost as much as you think.
I have to say that dodgy guides usually shows as smoke at startup only because there isn't enough running through them for it to smoke continously and it needs the oil to pool up in the ports while the engine is off before there's enough for a smoke screen. Permanant smoke under light load ususally points to a broken piston ring in my experience.
Edited by Dan, 19 December 2006 - 12:24 AM.
Posted 19 December 2006 - 01:29 AM
Posted 19 December 2006 - 02:22 PM
DRY
1= 160 2= 170 3= 165 4= 180
WET
1= 210 2= 200 3= 210 4= 250
Does this look like a ring problem then? I really hope not!
Posted 19 December 2006 - 02:32 PM
Hmmmm, from memory a mini engine takes more oil than that (I seem to recall more like 5 litres, but I really could be wrong so double check that). The 'doesn't even register on the dipstick' doesn't mean that all of that 4 litres has gone, it could be just below dipstick level, so it may not have used anywhere near 4 litres. Also bare in mind (as Dan has said) that the dipstick will read lower after you have run the car, than when you freshly re-fill.
If you are getting crankcase compression and pushing oil through the breather system (and lots of it, but not as much as we originally thought) then you will have nice yukky breather pipes. Are they full of oil?
It does seem possible/probable that you have ring problems though.
As Dan has said, valve guides, or stem oil seals usually allow some oil to trickle down to the crown of the piston whilst standing, causing big clouds on startup, then it usually clears. If you are getting snoke all the time, I guess you have 'problems down below'.
Posted 19 December 2006 - 03:57 PM
Posted 19 December 2006 - 04:40 PM
