Hi im lee, i have a 1979 mini clubman estate , it lives in the coventry area of the world, well nuneaton actually lol
It is white with a pair of black stripes up and over,
i love it to bits but its poorley !!!
For some reason when i lift the clutch the brake pressure drops? ???
we have changed the bios valve, but what i cant understand is that the two systems, ie brakes and clutch run indipendantly of one another,
yet like i say put it in gear , raise the cluth pedal to pull off and no brakes, yet pump the pedal a few times, and the pressure is there, but we dont always have time to pump the pedal four times before we can break do we !
any ideas?
BRAINTEASER FOR YOU
Clubby_nutta
, Dec 19 2006 06:24 PM
11 replies to this topic
Posted 19 December 2006 - 06:24 PM
Posted 19 December 2006 - 06:26 PM
Welcome to TMF
Have you checked the brake fluid level? Check for leaks aswell
Posted 19 December 2006 - 06:29 PM
Heylo Lee, welcome to TMF
I'm afraid I can't help with your problem, but just wanted to say I used to live in Coventry, & spent a lot of time in Nuneaton & Bedworth (or Beduff!) as a lot of my friends lived there
ho no not another nutter from nuneaton
welcome to tmf
welcome to tmf
Posted 20 December 2006 - 12:59 AM
Can you pump up the brakes to get a stiff pedal when its not in gear, or even when the engine is off?
Posted 20 December 2006 - 11:35 AM
Is it still on drum brakes all round? Might be an idea to check the wheel cylinders. I bought a Mini once and the seller said that you had to "double click" the brakes. First press of the pedal got the pressure, second press they worked.
Wheel cylinders where knackered.
Posted 20 December 2006 - 12:11 PM
Check the pedal box, had a similar thing on an old mini and where there had been a leak it had rusted the two pedals to the spindal!
Posted 20 December 2006 - 04:03 PM
I would first check all the brake pistons around the car for any leaking, possibly bleed a bit of fluid through and see if there is any air in the system. When was the last time the system was bled?
Posted 21 December 2006 - 03:58 PM
Hey try and check the brake master cylinder.The rubbers might be worn.
I had the same problem and replacing the master cylinder solved it.
GOOD LUCK.
GOOD LUCK.
Posted 21 December 2006 - 04:20 PM
I'm sure they wont mind me putting you on to them, but try and get hold of Central Minis, they are VERY local to you and even though a little odd have some great mini 'sperts in there.... and it's always better to have a touchy feely ( oh I'm going to regret saying that ) rather than trying to describe symptoms...
but basically sounds like your brakes need an overhaul..
http://www.theminifo...p?showforum=114
Posted 25 December 2006 - 02:15 PM
As Guessworks, said, speak to or join Central Minis.
TMF Member "Jake Blues" is a mamber, and is a top bloke. He might be able to help you out with the problem.
Posted 27 December 2006 - 03:48 PM
Welcome to TheMiniForum...
Hope you get it sorted !
