dead battery
12 replies to this topic
#1 Littlegizmos
Littlegizmos
    previously known as M1N1 MAN
  • 282 posts
  • Local Club: www.littlegizmos.co.uk
Posted 20 December 2006 - 01:24 AM
hi all
i have a 1995 n reg mini spi and after two days the battery goes flat if i dont use it. i have cleaned all the connections fitted three new batterys and new alternator but its stil doing it . i have put an amp meter on the battery to see it theres is any amps being drawn from the battery when all is off but its very low .5 amp witch should not be a problem. when i bought the car it had a battery cut off switch in the boot and i found a letter in service book from the first owner to say that they had the same problem so had this switch fitted.
anyone with an spi had the same problem????????????
Edited by M1N1 MAN, 20 December 2006 - 01:25 AM.
#2 minislapper
minislapper
  • 1,957 posts
Posted 20 December 2006 - 08:26 AM
Not heard of that one before.
Does it have an alarm fitted? I have heard of a lot of problems with alarms draining the battery.
#3 syholl
syholl
  • 710 posts
Posted 20 December 2006 - 08:28 AM
0.5 amps is quite a lot, thats like having your interior light left on all the time. That would be plenty enough to drain a Mini battery over a couple of days. I would start by checking things like the stereo first.
#4 The Matt
The Matt
  • 17,229 posts
  • Name: Matt
Posted 20 December 2006 - 08:29 AM
There must be an auxhilliary device draining the battery. I guess it could be caused by the alarm system, maybe in conjunction with something else? Over what period of time does the battery go flat?
#5 The Matt
The Matt
  • 17,229 posts
  • Name: Matt
Posted 20 December 2006 - 08:31 AM
Actually, yeah. What he said! :-
0.5 amps is gonna drain a 50Ah battery in 100 hours. Plus I assume that you tested it without the alarm turned on?
Are there any lights in glove boxes or anything daft that aren't turning themselves off?
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 20 December 2006 - 08:49 AM
you could go to the starter motor solenoid at the front of the engine, find the brown wires and disconnect these 1 at a time until the .5 amp drain goes
then try and find out what doesn't work to find your power drain :-
#7 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 20 December 2006 - 09:02 AM
Oh yes the dredded .5 amp Does your car have the standard rover radio or a removable front one
Try putting your meter back on and disconect the radio and see what happens, if its not that, try removing each fuse and observe the meter.
Some radios with the removable front depending how they have been wired can pull the battery down as the amp circuit still remains running.
Just my 2ps worth
#8 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 20 December 2006 - 10:04 AM
I have got the same problem with my automatic mini, i have searched everywhere buy i just cant find what is wrone with it :P
The only extra electrical parts i have fitted are three small gauges and two sport lights but i had the problem befor i fitted these, so they cant be the problem. Strange one.
I would just like to add this is my 1000 post :-:D
1000
1000
1000
1000
1000
1000
1000
Sorry thats enough of that now.
1000
1000
1000
1000
1000
Edited by Tomf, 20 December 2006 - 10:04 AM.
#9 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 20 December 2006 - 09:53 PM
measure the drain on the battery directly, then remove different things 1 by 1 til the drain stops!! an alternator is capable of draining the battery, so is a radio or an ecu or a relay!! or a chaffed wire!!
#10 milliemini
milliemini
  • 108 posts
  • Local Club: Bournemouth Mini Club
Posted 05 February 2007 - 01:52 PM
M1M1 Man, did you manage to find out what was draining your battery? I've got exactly the same problem on a '93 cooper, am probably going to end up fitting a battery cut off switch as a temporary solution I think.
#11 Littlegizmos
Littlegizmos
  • 282 posts
Posted 11 November 2007 - 11:20 PM
the problem was the ecu .had to change it with the alarm box under dash and key fob . all ok now
#12 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 11 November 2007 - 11:23 PM
plaese tell me it didnt take you a year to find out?
lol
#13 Littlegizmos
Littlegizmos
  • 282 posts
Posted 22 November 2007 - 08:10 PM
lol
no about 3 months. i had to buy another mini to use the ecu then sold the rest of the mini on ebay
