Oil or Grease
charlie
, Dec 21 2006 08:13 PM
12 replies to this topic
Posted 21 December 2006 - 08:13 PM
I'm going to lubricate all locks and hinges including boot and bonnet.
Is it best to use WD40 or a spray on grease (a grease in an aerosol that solidifies after a couple of seconds contact with the air)?
I'm doing the job with all parts and hinges in situ.
Thanks for any advice
Posted 21 December 2006 - 08:14 PM
spray on grease. i have a can of lithium aerosol grease for this sort of thing
Posted 21 December 2006 - 08:39 PM
Grease.
Sticks better.
Sticks better.
Posted 21 December 2006 - 08:43 PM
the spray on grease will be better than wd40 which is more off a penetrating oil than anything else
Will the grease attract and retain more dirt and dust?
Posted 21 December 2006 - 08:45 PM
we have this spray at work called white grease we use it for everything really good stuff
Posted 21 December 2006 - 09:45 PM
yeah white grease is good stuff, many uses. like putting on drill bits when drilling tough metal etc.
Posted 22 December 2006 - 12:05 AM
Excuse me if im wrong but i thought that grease and oil are used where metal to metal contact is not wanted. A drill bit by nature needs to contact the item being cut, putting a lubricant in there wont help.
A cutting fluid is required in this instance, this keeps the cutting tool and its leading edge cool, thereby increasing its 'sharp' life.
Edited by Mini Sprocket, 22 December 2006 - 12:06 AM.
Posted 22 December 2006 - 12:09 AM
Nah, neither.
Finishline synthetic lubricant FTW!
Posted 22 December 2006 - 12:28 AM
I use Vaseline for door locks etc. I found it works great, doesnt attract dirt etc. But my car does ony 2000 miles per year.
Posted 22 December 2006 - 01:07 AM
I go with spray grease for the hinges and door latches but the lock cylinders themselves should be blown through with graphite powder.
Posted 22 December 2006 - 11:16 PM
I've used vaseline too (on the lock strikers that is, so it doesn't ruin your clothes), but just use 3 in 1 (or everyman) oil inside the actual lock barrels.
Posted 23 December 2006 - 02:30 AM
and what about lubricating the hinges :) ho ho ho
