Hi
Our open classic is still not 100% on tickover when cold. Cleaned the carb, new airfilter, plugs, tappets ok etc. Gonna change the dizzy cap rotor and leads (though i suspect these would cause problems when hot too) but for £20 they could do with changing anyway.
Just been reading the haynes manual, ours has the charcoal canister thingy for vapours from the fuel tank. In the system description it mentions the system only comes when normal operating temperature is reached "to ensure the engine runs correctly when cold". Are problems with the canister and its valves etc common/uncommon, could it be causing my problems.
thanks
Gary
cold tickover
geepeetee
, Dec 24 2006 11:55 AM
4 replies to this topic
Posted 24 December 2006 - 11:55 AM
Posted 24 December 2006 - 11:59 AM
does the car run ok once it is warm?
Posted 24 December 2006 - 12:08 PM
Hi
Thanks for your reply, yeh it runs fine when warm
Gary
Gary
Posted 24 December 2006 - 01:42 PM
well could it not just be the cold weather. use the choke until the engine starts to pick up.
Posted 24 December 2006 - 02:14 PM
you shud be on choke til about 1/4 of engine temperature, mite just need a good service as you say.
