right, i took my carb off to stop a leak (its the waxstat carb) and the leak seemed to come from the delivery pipe at the bottom of the resevior to the jet housing so i tighten up the nut on the resivior cleaned up the carb stuck it back on put the pipes on turned the key and it started revved up fine the she cuts out and theres petrol comin from the second pipe from the resivior and on the floor, i was goin to take it all apart 2moz to see if i can fix the prob but if n e 1 has ne ideas i would be gkad to hear them
ps sorry for the lonf essay
carb trouble
FARRANTINO
, Dec 24 2006 06:35 PM
5 replies to this topic
Posted 24 December 2006 - 06:35 PM
Posted 24 December 2006 - 06:41 PM
Sounds like the float bowl needle/cap wants adjusting
Someone will be able to explain this to you.
Posted 24 December 2006 - 06:51 PM
ok thanks for that ill try sometime 2 moz and what if it inst that what else could it be
Posted 24 December 2006 - 06:53 PM
possibly blocked pipe to the jet. When you put it back on, did you blow through it and clean the inside of the float chamber? Also did the little washer go back on correctly.
Just afew ideas.
Just afew ideas.
Posted 25 December 2006 - 02:07 PM
it was the float thx for the help
Posted 25 December 2006 - 02:23 PM
No worries. Glad your sorted.
Jordie
Jordie
