my reverse lights dont work. i have checked the bulb there fine. nothing else has stopped working so i dont think its the fuse. any ideas?
reverse lights
davexdavexdave
, Dec 25 2006 01:26 PM
3 replies to this topic
Posted 25 December 2006 - 01:26 PM
Posted 25 December 2006 - 01:50 PM
have you checked the switch the earth and the fuses? merry christmas !
Posted 25 December 2006 - 02:00 PM
check wires to switch, check switch, check both bulbs working.
Posted 26 December 2006 - 02:40 PM
a wire could have come off the switch on the linkage!! thats what i've seen lots before! if your brake lights are working then the fuse is ok.
if you dont fancy climbing under the car, inside the car under the carpets by the exhust tunnel there are 2 wires that come down from behind the heater, these are the reverse ones. there is a plug somewhere around there,try linking them together with a piece of wire and seeing if they come on! if they do its the switch.
